Hi all and thanks for approval,
I have a DAc X6 and I am using it as a preamp/dac for my DENON poa 3012ci. I have 4 speakers connected and sending digital signal from my PC via USB. I am experiencing loud clicking and popping noises every time the dac is receiving audio signals.
For example if I am listening to any youtube video and during the video there is a short period of time with no sound the green light on my dac will go off and I will hear a noise in my speakers, as soon as any digital is being sent to the dac the green light will turn on and I will hear another annoying sound. Imagine that you want to skip some footage on a video or you are watching a mouvie and there is a short or long moment of silence, I will hear popping all the time.
I tried the optical cable as well and I am having the same results.
Is there any way I can make the DAC to stay on all the time. Bypass the automatic signal detector so the green light is on all the time.
Thanks
Thanks
