Jul 3, 2017 at 8:42 AM Thread Starter Post #1 of 3
HT98
Ballenstedt
Hi all out there. I have write this post in another section, too. I think a new thread is better for this. Hope that anybody can help me in that way. I have made a big mistake. I
wanted to change three files, in the etc Folder. It was these:
mixer_paths.xml, mixer_paths_high_model.xml and mixer_paths_auxpcm.xml. I
thought to believe that i could take higher the headphone output volume
without perform a backup before.To my stupidity, I extinguished then these
files, cause the half setting that i have made was perfect, but i have
changed to many values at once, so i cannot identify what value makes the
error (no sound). Can one of you extract and give me these data. I would appreciate it, so i can do a backup imminently. Then I have optinal questions,
so just out of curiosity. Can you tell me the right
settings to make the headphone output louder, what i had setup are the RX1
and RX2 values, but no change. And where i can
setup the microphone settings, for example Mic PGA Capture Volume. So that
was it. I hope you can help me. I say already thanks for your assistance and to cancel my Misfortune.
Friendly regards, HT98.
Jul 11, 2017 at 12:27 PM Post #3 of 3
It would be nice if one of you can do that. copy out this 3 little round 50kb big files:
mixer_paths.xml, mixer_paths_high_model.xml and mixer_paths_auxpcm.xml. with f.e. es file explorer than in the system folder -> etc, there are the 3 files.
