Help Finding the Sweet Spot: Amp/iPod Volume Settings
May 3, 2009 at 9:16 PM Thread Starter Post #1 of 9
f00fighters
I want to know if there's a standard volume setting of an Amp, and an iPod/iPhone when using them together. As of right now, I've been putting the volume all the way up on the iPhone 3G, and adjusting my amp volume accordingly. Is this correct? I want that sweet spot where the sound is simply amazing. I'm guessing this answer varies, depending on the source and amp.
I'm using an iPhone 3G with lossless music and a C&C XO portable amp with a pair of AKG K702's, and a pair of Shure SE530's.
May 4, 2009 at 12:08 AM Post #2 of 9
billybob_jcv
May 4, 2009 at 2:14 AM Post #3 of 9
MacedonianHero
Headphone.Guru Editor
Toronto, Canada
Originally Posted by billybob_jcv /img/forum/go_quote.gif
Why not use a line-out dock (LOD) cable? Make sure you get one that is compatible with the iphone.
Or a Pocketdock:
SendStation - Products - PocketDock Line Out USB
Absolutely...I hear things from my Pocketdock that I simply miss using the headphone out from my ipods.
May 4, 2009 at 2:35 AM Post #4 of 9
GreatDane
Virginia
Trust the Hypnotoad. The Hypnotoad will not steer you wrong.
X3 for LOD.
May 4, 2009 at 8:30 PM Post #7 of 9
f00fighters
I appreciate that. Will get an LOD right away. This may sound stupid, but I see all kinds.. on ebay they're going for $43 to over $100! The cables seem to be a lot thicker. Is this going to make a huge noticeable difference in the sound? The pocket dock is more of a reasonable price.
May 4, 2009 at 8:41 PM Post #8 of 9
qusp
Member of the Trade: Twisted Cables
Originally Posted by smeggy /img/forum/go_quote.gif
Yes, volume all the way up and adjust with the amp.
I could be mistaken but I believe like most other digital devices, when you reduce volume you also reduce bitrate, so doing it in the analog domain of your amp is best.
no it does not reduce the bitrate, but it does try and perform a transform on the numbers that describe the audio signal and not all the operations (probably not many at all) divide accurately, so there are some glitches in the signal that means the signal is not ideal as it is at full volume where it is using whole numbers.
so basically 2x2 sometimes equals 5 and sometimes equals 3; you know what I mean?? thats obviously not to be taken literally, but I hope thats easy to understand. the analogue volume pot does not act on numbers, it acts on the waves that the numbers describe, which can be infinitely divided without leaving a remainder
clear as mud??
May 5, 2009 at 4:59 AM Post #9 of 9
f00fighters
qusp, thanks for confusion. I am much obliged.
