So I recently bought a Chinese made DAC/AMP combo from an eBay seller minishow0328.
http://www.ebay.com/itm/141639172871?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Specs:
DAC: Burr Brown DSD1796 chip
AMP: MAXIM MAX4410
Resolution support: DSD64, DSD128 and PCM 32/384K
The problem is that I can't seem to get it to playback high resolution PCM (FLAC etc) or DSD properly. It's a XMOS U8 platform, running on Windows XMOS stereo Class 2 Audio driver version 2.23. I can get the device to play up to DSD64 (but seems to convert to PCM) and FLAC 24/96K. Anything higher and the sound starts to degrade and generate hiss. Can anyone here please help? I've tried so many times to get it to work...
I've so far tried on 3 machines, 2 running windows 8.1, one freshly installed.
One running Windows 7.
Here are the steps that I've taken and the settings:
1. Plug in DAC to PC using USB cable. DAC powered by external source, running 7-8 Volts. It's a 2.5A adapter so I'm sure it's enough.
2. Windows driver install fails since it's not a universal driver device. Proceed to install XMOS stereo USB 2.0 driver V2.23.
3. Set as default device in Windows Sound Manager.
4. Install Foobar 2000, running version 1.3.8
5. Install SACD and ASIO plugin
6. Set playback device to ASIO
7. ASIO config:
Specs:
AMP: MAXIM MAX4410
7. ASIO config:
