slag
- May 3, 2005
I have a pair of SR60's which I ordered from Drew at Moon Audio; they're custom cut to a 40" cord for portable use. They are used almost exclusively with an iRiver H320 running the latest Rockbox.
Every once in a while, while I'm walking around, I'll notice a little "rattling" distortion in the sound of the right speaker. It's that static sound that you hear when you get a bad audio connection. It "jiggles" a little bit as I'm walking and when I turn my head, but doesn't happen all that often or consistently.
Finally, sometimes while I'm listening to music, the right speaker will start to diminish in volume. It seems to be a slow fade - but eventually will be so faint that I can barely detect any output in the right speaker at all. The left, however, will continue to function normally at full volume during this time. Plugging the headphones into a different audio source that is producing output for a second or two, then switching the headphones back into the H320 will fix the problem.
What the heck is going on, here? Where could the problem lie, and why is it so inconsistent?
EDIT: added a few more details to my description
