Help about Hiby R6 as transport
Oct 22, 2019 at 11:40 AM Thread Starter Post #1 of 3
Ryan Mok
Hk
Dear all,
I have tried to connect the hiby r6 via USB to Chors hugo 2 to play spotify. But the light of hugo 2 turn green which mean the data passing from hiby r6 is 96kHz. Is it correct as spotify should be 44.1Hz?
Oct 22, 2019 at 6:27 PM Post #2 of 3
Dear all,
I don’t have the R6 but Have a R6 Pro and I use the Coax output not for sure if the R6 has it or not but I wouldn’t worry about it as it might be upsampling the output which will not effect the sound.
Oct 22, 2019 at 9:11 PM Post #3 of 3
Thanks for your reply.
Can you tell me whether the sampling rate will be correct if you use coax instead
