dr.morton
- Apr 21, 2006
Sometimes the problem lies with the source.
For example if I use an amp with my Monolith or Cowon A2 through the headphone out the sound does only change a tiny little bit. With the A2 it only gets worse.
The same happens when I connect the amp to the A2 line out. No real improvement whatsoever.
There are a lot of people claimig that iPod and an amp only make sense when they are connected through the dock line out of the iPod.
So maybe the source is the trouble, not the amp.
If you use a laptop as source (with optical out) maybe you should consider a DAC then.
