Jan 6, 2025 at 2:24 PM Post #331 of 345
Jan 7, 2025 at 10:50 PM Post #334 of 345
I'm just excited to see a woman interested in headphones from a non cosmetic viewpoint.
Jan 23, 2025 at 9:46 AM Post #335 of 345
How is the clamp force compared to the regular Heddphone 2? I loved the sound on those, but my big head couldn’t handle the clamp force even at the lowest setting.
Jan 25, 2025 at 7:18 PM Post #336 of 345
I've never worn the OG H2 but I'm pretty sure the ergonomics of the two are identical. I can tell you, however, that the velour pads on the GT are comfortable enough to mitigate the clamping pressure a lot. I'd say that clamp force is necessary, though, because of a combination of the set's weight and needing to ensure a seal is maintained while moving your head around on all axis.
By the way, it's unique ergonomics allows it to fit over (likely) any VR headset and keep it in place perfectly. Surprisingly, it's hefty weight combined with a bulky VR headset doesn't actually bother me at all... I believe this is a direct result of the correct amount of clamping pressure. I can finally enjoy VR gaming without compromising on audio quality! The GT is a BIG TIME keeper for me.
Jan 28, 2025 at 5:48 PM Post #337 of 345
Hm.
Hard to say, but i'd rang the GT pads a bit stiffer than the H2 pads.
GT pads will stay in shape much longer.
Could cause more trouble based on your description.
Jan 28, 2025 at 5:57 PM Post #338 of 345
Hm.
Thanks. I’ll just move on. 👍
Jan 29, 2025 at 9:42 PM Post #339 of 345
I might as well share a sneak peek into my review too then, it's not yet published but happy holidays and all that: https://www.techpowerup.com/review/heddphone-two-gt-air-motion-transformer-headphones/
I must say, your reviews are truly superb, from every and any vantage point. They exude detail and quality and are a clear demonstration of the labor of love you have for the hobby. I just wanted to personally thank you and extend my highest compliments. I find them a tremendously valuable contribution.
I just had a chance to attend a HEDD/Headphones.com event yesterday and walked away convinced that the GT will be in my collection. I actually just read your review today and it aligns with my exact sentiments from yesterday.
PS- try to get your hands on ES Labs ES-2a (corrected the few minor weaknesses of the ES-1a) they will be special
Jan 30, 2025 at 5:47 PM Post #340 of 345
Thank you for your kind words.
Unfortunately ES Labs had previously mentioned they don't have review loaners, and there are no dealers in the UK either to help with testing one out.
Jan 31, 2025 at 8:13 PM Post #341 of 345
Why does this headphone reminds of Meze Empyrean? Their hand made? production process and built structure is almost identical to each other.
Feb 1, 2025 at 2:21 PM Post #342 of 345
First release of finished/“polished” sets will be in March according to Mr. Benson Wong. So maybe after that review units will be sent out?
Feb 1, 2025 at 9:18 PM Post #343 of 345
is it true that this headphone sounds better than Caldera?
Feb 2, 2025 at 4:49 AM Post #344 of 345
