Like very fine articulated treble to the point that Empyrean compared sounds metallic!
Who have ever thought of that!
Listen as long as you can each day. After a couple weeks, you will be able to listen pretty much all day (seriously). If you go a week without listening, you will also lose that ability again.I gotta say, these cans sound pretty insane. One of the very few headphones that let's you truly hear into the recording. Transients are second to none, bass very linear, mids are very nicely presented with minimal harshness and the treble is pretty spectacular. The whole FR seems to have a certain weight and depth on these, treble being extremely detailed yet somehow soft sounding and non-fatiguing.
With KaiS EQ it fixes a few FR problems and adds a bit of fullness and mid-range detail:
G +3.0 F 470 Q 2.0 (Peak)
G: -4.0 F 710 Q 4.0 (Peak)
G:+5.0 F6.0k Q 5.0 (Peak)
It's pretty hard to put these down, though unfortunately I do give in to the weight after an hour or 2. If anyone could recommend a certain headband padding that would be great, I was personally thinking about adding a ZMF pilot pad.
Thanks for the suggestion, gotta give those neck muscles a good workout. Guess I'll give it some more HEDDtime.Listen as long as you can each day. After a couple weeks, you will be able to listen pretty much all day (seriously). If you go a week without listening, you will also lose that ability again.
Is it available online ?I got a pad that is really not even padded much to go over the headband and I thought it wouldn't work but it pads the middle just enough that I no longer have a problem wearing them for a few hours. The middle of my headphone doesn't get uncomfortable anymore which is great and since the weight doesn't bother me anymore I'm good to go.
