Headphones sound muted when plugged in to PC speakers
Dec 27, 2004 at 1:44 AM Thread Starter Post #1 of 2
perdomot
I recently bought some Logitech Z-3 2.1 speakers that sound great but when I connect my headphones to the base where the volume knob is, the volume is considerably lower. Is this a fault of the speakers or am I doing something wrong? My old cheap 2 piece speakers didn't do this so I'm thinking its the new speakers. Thanks.
Dec 27, 2004 at 3:25 AM Post #2 of 2
i have logitech z640s and use that. the volume knob on the speakers adjusts the speakers only.
if you plug you headphones into the speakers you have to adjust the volume via the sys tray.
thats prolly your issue.
