xnor
- May 28, 2009
The following table is based on measurements, not manufacturer specs.
Target SPL is 110 dB SPL.
The source is assumed to output 2 V. The amp is assumed to be a voltage source (0 ohm output impedance).
Voltage, current, power are RMS figures.
What do the columns mean?
S@1V is the sensitivity with 1 V, 500 Hz sine wave input in dB SPL.
Z is the impedance at 500 Hz in Ω.
Voltage is the required voltage to reach the target SPL.
Current is the required current to reach the target SPL in milliamperes.
Power is the required power to reach the target SPL in milliwatts.
Gain is the gain the headphone amplifier theoretically needs to reach the target SPL without excess gain. If needed you can add a few dB excess gain (suggestion: 3 to 9 dB).
Notes:
There is no guarantee that the data is 100% correct. The sensitivity of some headphones can vary as much as +/- 3 dB (some manufacturers even specify this explicitly).
Some have raised concerns with 110 dB SPL being too loud. Well, that is just the absolute highest SPL you can reach with a full-scale 500 Hz tone and the volume set to max.
Music has a higher crest factor than sine tones, which means that the RMS value will be much lower.
The following graphic shows a volume control with a 15A taper pot as found in many heapdhone amps. Ideal range should be somewhere between 10 and 2 o'clock.
The inner labels show the attenuation of the pot at each full hour. So 110 becomes 95 dB SPL at 12 o'clock.
The outer blue/red labels show the overall perceived SPL of an uncompressed classical track and a heavily compressed metal track respectively. Loudness was calculated using an EBU R128 compliant scanner.
Obviously, you can really hurt your hearing if you listen to highly compressed music and turn up the volume. With less compressed music overall levels will be a lower but there can still be very loud passages or short peaks in SPL.
So turn the volume down - better be safe than sorry. Don't rely on calculations only. Use a sound level meter.
Please let me know if you find that some values are completely off or want some headphones added.
Notes:
- 1 kHz: the measurement was done at 1 kHz instead of 500 Hz
- specs: based on specifications provided by the manufacturer, not independent measurements
- nc: noise canceling enabled
Manufacturer | Model | S@1V [dB SPL] | Z [Ω] | Voltage [V] | Current [mA] | Power [mW] | Gain [dB] | Notes |
AKG | K240 Studio | 103 | 64 | 2.239 | 34.98 | 78.311 | 1 | |
AKG | K271 MK II | 106 | 65 | 1.585 | 24.383 | 38.644 | -2 | |
AKG | K272 HD | 110 | 65 | 1 | 15.385 | 15.385 | -6 | |
AKG | K550 | 115 | 35 | 0.562 | 16.067 | 9.035 | -11 | |
AKG | K601 | 99 | 131 | 3.548 | 27.085 | 96.101 | 5 | |
AKG | K701 | 105 | 65 | 1.778 | 27.358 | 48.65 | -1 | |
Audeze | LCD-2 | 108 | 45 | 1.259 | 27.976 | 35.22 | -4 | |
Audeze | LCD-3 | 102 | 48 | 2.512 | 52.331 | 131.449 | 2 | |
Audio Technica | ATH-AD700 | 113 | 35 | 0.708 | 20.227 | 14.32 | -9 | |
Audio Technica | ATH-AD900 | 114 | 37 | 0.631 | 17.053 | 10.76 | -10 | |
Audio Technica | ATH-AD900X | 114 | 38 | 0.631 | 16.604 | 10.477 | -10 | 1kHz, specs |
Audio Technica | ATH-ANC7B | 118 | 305 | 0.398 | 1.305 | 0.52 | -14 | nc |
Audio Technica | ATH-ANC9 | 109 | 100 | 1.122 | 11.22 | 12.589 | -5 | nc |
Audio Technica | ATH-M50 | 115 | 38 | 0.562 | 14.798 | 8.322 | -11 | |
Beats by Dr. Dre | Pro | 117 | 18 | 0.447 | 24.816 | 11.085 | -13 | |
Beats by Dr. Dre | Studio | 121 | 216 | 0.282 | 1.305 | 0.368 | -17 | nc |
Beyerdynamic | Custom One Pro | 116 | 18 | 0.501 | 27.844 | 13.955 | -12 | |
Beyerdynamic | DT770 Pro | 98 | 251 | 3.981 | 15.861 | 63.143 | 6 | 1kHz |
Beyerdynamic | DT770-32 | 111 | 32 | 0.891 | 27.852 | 24.823 | -7 | |
Beyerdynamic | DT770-600 | 100 | 557 | 3.162 | 5.677 | 17.953 | 4 | |
Beyerdynamic | T1 | 99 | 750 | 3.548 | 4.731 | 16.786 | 5 | |
Beyerdynamic | T5p | 116 | 41 | 0.501 | 12.224 | 6.127 | -12 | |
Beyerdynamic | T70 | 110 | 380 | 1 | 2.632 | 2.632 | -6 | |
Beyerdynamic | T90 | 102 | 308 | 2.512 | 8.155 | 20.486 | 2 | |
Bose | AE2 | 112 | 36 | 0.794 | 22.065 | 17.527 | -8 | |
Bose | QC15 | 113 | 4800 | 0.708 | 0.147 | 0.104 | -9 | nc |
Bowers & Wilkins | P5 | 117 | 27 | 0.447 | 16.544 | 7.39 | -13 | |
Denon | AD-D2000 | 115 | 25 | 0.562 | 22.494 | 12.649 | -11 | |
Denon | AH-D1001 | 112 | 31 | 0.794 | 25.623 | 20.353 | -8 | |
Denon | AH-D7000 | 114 | 25 | 0.631 | 25.238 | 15.924 | -10 | |
Denon | AH-D7100 | 108 | 30 | 1.259 | 41.964 | 52.83 | -4 | |
Fischer Audio | FA-003 | 117 | 75 | 0.447 | 5.956 | 2.66 | -13 | |
Fostex | T50RP | 107 | 54 | 1.413 | 26.158 | 36.949 | -3 | |
Fostex | T7 | 113 | 80 | 0.708 | 8.849 | 6.265 | -9 | |
Fostex | TH900 | 108 | 25 | 1.259 | 50.357 | 63.396 | -4 | |
Grado Labs | SR60i to 325i | 111 | 34 | 0.891 | 26.213 | 23.363 | -7 | |
Hifiman | HE-4 | 90 | 63 | 10 | 158.73 | 1587.302 | 14 | |
Hifiman | HE-500 | 102 | 34 | 2.512 | 73.879 | 185.576 | 2 | |
Hifiman | HE-6 | 89 | 43 | 11.22 | 260.935 | 2927.734 | 15 | |
Hifiman | Re0 | 118 | 60 | 0.398 | 6.635 | 2.641 | -14 | |
KRK Systems | KNS6400 | 110 | 34 | 1 | 29.412 | 29.412 | -6 | |
KRK Systems | KNS8400 | 106 | 35 | 1.585 | 45.283 | 71.768 | -2 | |
Sennheiser | Amperior | 113 | 22 | 0.708 | 32.179 | 22.781 | -9 | |
Sennheiser | CX880 | 120 | 34 | 0.316 | 9.301 | 2.941 | -16 | |
Sennheiser | HD202 | 119 | 34 | 0.355 | 10.436 | 3.703 | -15 | |
Sennheiser | HD280 Pro | 114 | 73 | 0.631 | 8.643 | 5.454 | -10 | |
Sennheiser | HD555/595 | 114 | 72 | 0.631 | 8.763 | 5.529 | -10 | |
Sennheiser | HD558/598 | 112 | 70 | 0.794 | 11.348 | 9.014 | -8 | |
Sennheiser | HD600 | 105 | 322 | 1.778 | 5.523 | 9.821 | -1 | |
Sennheiser | HD650 | 104 | 333 | 1.995 | 5.992 | 11.955 | 0 | |
Sennheiser | HD700 | 105 | 199 | 1.778 | 8.936 | 15.891 | -1 | |
Sennheiser | HD800 | 103 | 430 | 2.239 | 5.206 | 11.656 | 1 | |
Sennheiser | IE800 | 125 | 18 | 0.178 | 9.879 | 1.757 | -21 | |
Sennheiser | PX100 II | 114 | 34 | 0.631 | 18.558 | 11.709 | -10 | |
Sennheiser | PX200 II | 115 | 38 | 0.562 | 14.798 | 8.322 | -11 | 1kHz |
Shure | SE215 | 126 | 18 | 0.158 | 8.805 | 1.395 | -22 | |
Shure | SE535 | 133 | 36 | 0.071 | 1.967 | 0.139 | -29 | |
Shure | SRH1440 | 107 | 38 | 1.413 | 37.172 | 52.507 | -3 | |
Shure | SRH1840 | 102 | 66 | 2.512 | 38.059 | 95.6 | 2 | |
Shure | SRH440 | 116 | 41 | 0.501 | 12.224 | 6.127 | -12 | |
Shure | SRH750 | 113 | 39 | 0.708 | 18.152 | 12.851 | -9 | |
Shure | SRH840 | 116 | 44 | 0.501 | 11.391 | 5.709 | -12 | |
Shure | SRH940 | 113 | 40 | 0.708 | 17.699 | 12.53 | -9 | |
Skullcandy | Aviator | 118 | 36 | 0.398 | 11.059 | 4.402 | -14 | |
Skullcandy | Crusher | 114 | 32 | 0.631 | 19.717 | 12.441 | -10 | 1kHz, specs |
Skullcandy | Mix Master | 119 | 20 | 0.355 | 17.741 | 6.295 | -15 | |
Sol Republic | Tracks | 118 | 60 | 0.398 | 6.635 | 2.641 | -14 | 1kHz |
Somic | MH463 | 106 | 45 | 1.585 | 35.22 | 55.82 | -2 | 1kHz, specs |
Sony | MDR-MA900 | 111 | 15 | 0.891 | 59.417 | 52.955 | -7 | |
Sony | MDR-XB1000 | 115 | 27 | 0.562 | 20.827 | 11.712 | -11 | |
Sony | MDR-XB500 | 123 | 43 | 0.224 | 5.206 | 1.166 | -19 | |
Sony | MDR-XB700 | 115 | 28 | 0.562 | 20.084 | 11.294 | -11 | |
Superlux | HD668b | 108 | 61 | 1.259 | 20.638 | 25.982 | -4 | |
Superlux | HD669 | 110 | 62 | 1 | 16.129 | 16.129 | -6 | |
Takstar | HI2050 | 104 | 60 | 1.995 | 33.254 | 66.351 | 0 | 1kHz, specs |
Ultrasone | Edition 8 | 115 | 34 | 0.562 | 16.539 | 9.301 | -11 | |
Ultrasone | HFI580 | 115 | 36 | 0.562 | 15.621 | 8.784 | -11 | |
Ultrasone | HFI680 | 115 | 75 | 0.562 | 7.498 | 4.216 | -11 | |
Ultrasone | HFI780 | 116 | 40 | 0.501 | 12.53 | 6.28 | -12 | |
Ultrasone | Pro550 | 117 | 65 | 0.447 | 6.872 | 3.07 | -13 | |
Ultrasone | PRO750 | 114 | 41 | 0.631 | 15.389 | 9.71 | -10 | |
Ultrasone | PRO900 | 108 | 43 | 1.259 | 29.277 | 36.858 | -4 | |
V-Moda | Crossfade M100 | 115 | 36 | 0.562 | 15.621 | 8.784 | -11 | |
Yamaha | PRO 300 | 116 | 58 | 0.501 | 8.641 | 4.331 | -12 |
