Headphones for Death/Black/Thrash metal - advice needed
Jan 17, 2014 at 8:47 AM Thread Starter Post #1 of 11
Golota
Hi guys,
I'm a complete noob when it comes to the world of headphones. I'm currently using a V-Jays set, which I really like. Unfortunately, I stepped on them and thes seem to be beyond repair now. I have been lurking here for a few weeks and kind of got the head-fi bug, so now I'm looking for a replacement.
I normally listen to bands like: Death, Slayer, Behemoth, Inquisition, Immortal, Dimmu Borgir,etc  with occassionally some lighter genres, but almost exclusively rock/amped guitar based.
These are my requirements:
- They needto be portables to some extent. Not for sports, but for walking, biking and travel.
- I have little kids and a wife, whom I don't want to wake up, so I would prefer closed earphones
- I don't like IEMs. Can't wear them, got serious tinnitus, even at low volume.
- Using my phone Samsung S3 with "good quality" mp3s and flac files. No amplification.
- I really like punchy bass, but of course these are mostly guitar based genres.
I more or less narrowed it down to Beyerdynamic DT770, Sennheiser HD25-1-II, Creative Audio Live. Grados are not really an option, as they are not sold where I live and it would be really expensive, plus they leak sound (from what I have heard)
I do not wat to spend a fortune, so up to say 200 USD. Is the DT770 or the HD25 that much better than the CAL with my set-up, that they justify the double price? What else could you recommend?
Thanks a lot guys, your help is really appreciated.
Jan 25, 2014 at 11:27 AM Post #2 of 11
No replys?
I'm also looking at Superluxes, especially the 662 series (have no ide which one B or F).
A couple of samples to what I'm listening to:
So what I'm looking for is a headphone that has:
- Instrument separation
- Punchy, but tight bass for kickdrums
- Can handle speed
Any ideas?
Jan 25, 2014 at 10:28 PM Post #3 of 11
Among those you listed, and considering you'll use them straight out of an S3, I'd say the HD25-II is your best bet. They'll handle double pedal drums well enough (I've tried them with a Cowon S9 - amplification specs shouldn't be too different), and one of the songs I tested was Ov Fire and the Void. Just be careful about cranking them up because the earpads don't go completely around your ears, so there will be enough of a gap between them and your skin where sound can leak out (but basically just don't use them at high volume right next to somebody sleeping).
Jan 26, 2014 at 11:46 AM Post #4 of 11
Thanks!  was checking out prices, but it seems like the HD25 is almost 300USD where I live and the Beyer is similarly priced, so I will probably have to go for something cheaper...I'm currently looking at the Superlux HD662 and the CAL. I'm reading very mixed opinions on how these compare, so I could use an educated opinion here. Is there anything else I should consider in the 100 USD range?
Jan 26, 2014 at 1:23 PM Post #5 of 11
None that I know of, as I haven't tried any Superlux. Conflicting reports on those can be from vastly different experience of users - those who are upgrading from cheap systems of all sorts (if they have speakers at all), and those who might be looking for a cheaper alternate headphone coming from a better system (even if it's just speakers). The former might be easily amazed while the latter are awfully underwhelmed and they don't even take into account if they're a great buy at that price (or they have a cheap, go-to fave, the SR60 - which is something nearly half of all people I know on speakers have).
Jan 26, 2014 at 2:14 PM Post #6 of 11
Takstar Pro 80 could be a better option for you than the CAL. Check out the Takstar thread there are some comparisons and lots of good information. I know nothing of the Samsung S3 though, you might need a dac/amp solution (from my clip+ they seem fine for metal). Just listened to some Pantera & Metallica (Mac Mini > E17). Sounded decent.
The big downside is the coiled cable which could be annoying for walking etc. (They are changing this apparently)
Jan 27, 2014 at 2:48 AM Post #7 of 11
Thanks for the advice. I checked the Takstar and it seems to get good reviews. How does that measure up against the Superlux HD662? The Takstar costs 2x as much as the Superlux. Can I assume that the price difference is justified?
Jan 30, 2014 at 7:47 AM Post #11 of 11
After reading through various threads, I settled with a Takstar Pro 80. I ordered it from China. Can't wait to get my hands on it. Thanks, everyone.
