Headphones bottoming out? Help
Dec 5, 2007 at 4:07 AM Thread Starter Post #1 of 13
Chris Tch
I know I just posted a review of how much I love my AD900s, but there seems to be a problem with them. Whenever I turn the volume up to a moderately loud level, the right channel especially seems to make a clicking noise during heavy bass passages. It claims to take up to 700 mW of power, and I seriously doubt I'm giving it anywhere close to that. The left channel makes a slight fuzzy sound when the bass is loud, but the right side is the one that's worrying me with the clicky noises. If anyone knows what the problem might be, please let me know. I doubt it's a hair, because it would make more of a buzzing than a clicking noise. Also, if there is something wrong with it, do you think Audiocubes would take them back for repair?
Edit: Seems to happen mostly around 20-35Hz. Also, does anyone know how easy it is to take off/put back on the earpads?
Thanks,
Chris
Dec 5, 2007 at 4:27 AM Post #3 of 13
I have a laptop output into a Mini3 amp. I doubt it's clipping, but I'll try another source to make sure. Also, is it easy to put the pads back on, or would I need some sort of device to slide them back on?
Edit: Nope, other source does the same exact thing. It's definitely the headphones.
Dec 5, 2007 at 4:43 AM Post #5 of 13
sounds a lot like amp clipping. but make sure you don't have any enhancements on your source, like crazy high eq'ing or some sort of feature that adds loudness or bass.
check for hairs.
otherwise it could be the phones.
Dec 5, 2007 at 4:53 AM Post #6 of 13
I don't see any hairs, and I shined a flashlight through the back to see if I could find anything. I don't use any bass enhancements except for EQing, and I lower everything else below 0dB instead of raising the bass. I tested it with GoldWave, which has a pure expression evaluator.
Dec 5, 2007 at 4:55 AM Post #7 of 13
check for hairs.
Yes but unless the battery is nearly dead, or the mini3 is malfunctioning, it aint clipping. Unless the source is clipping, but into a 35-ohm headphone, he shouldn't need to crank it all the way.
The average mini3 has an 8.4v battery and the opamps used can swing very close to the rails. His headphones only need about 5v peak to peak to achieve the max 700mw.
Dec 5, 2007 at 4:57 AM Post #9 of 13
one last question - did you build the mini3 or buy it?
If it has a dc offset, that would change the minimum or maximum excursion of the driver, which could cause some very bad things to happen.
So, if you built it yourself, you did test it, right? And you know your source has no DC offset? Because the mini3 will amplify any DC offset it gets in the input signal.
Dec 6, 2007 at 2:38 AM Post #12 of 13
Originally Posted by Chris Tch /img/forum/go_quote.gif
Any other ideas what it could be/how I could fix it?
Got any other sources?
