Headphone volume threshold....
May 29, 2003 at 3:32 AM Thread Starter Post #1 of 5
BillyHOEZ
hey guys....just wondering....is there such thing as a threshold operating volume for headphones? i've always been curious about that...and wondered if turning up the volume levels to the point where the sound begins to distort would cause permanent damage to the speakers and or voice coils themselves....thanks....
May 29, 2003 at 3:40 AM Post #2 of 5
Be more concerned with YOUR damage but yes you will blow teh drivers and coil if you over drive them for an extended period of time.
May 29, 2003 at 3:46 AM Post #3 of 5
Just stay below '11' on your amp!
May 29, 2003 at 4:58 AM Post #4 of 5
there is a distortion level which, once you pass a certain volume level, everything gets distorted very quickly. this distortion will cause more hearing damage than just plain high volume. this distortion is very likely to burn out a driver.
got a headphone? turn up the volume. if you reach a volume level which distorts before full volume, (usually high effeciency headphones), you are reaching it's optimum.
if however you turn up the volume where you have to remove them from your head without distortion - they are good headphones.
oh, maybe it's the amp? then try another, different, amp. same thing happen? chances are it's the headphone. (provided that it's a different impedance loading amp).
listen to the DT880, CD3000 and the HD600 at past-full-volume. they all have a high dynamics threshold.
turning up Grados (or Audio Technicas) until they distort isn't hard. the volume isn't what is causing you to turn the volume down - it's the distortion.
be careful when you turn up the volume on the DT880. it can cause hearing damage. why? because it's pure SPLs and not distorted SPLs.
May 29, 2003 at 6:03 AM Post #5 of 5
Just make sure you don't blow up the drivers in your brain, where from then on, you'll have to lay motionless on a hospital bed like a vegetable,
