Headphone Help
May 13, 2012 at 7:08 PM Thread Starter Post #1 of 14
Kema
Okay, I need you guys' help here gonna get headphones.
Here's what I have, remember I DO NOT have an AMP and do not want to buy one. I want a good all-around headphone, not with too much bass. COMFORT is a MUST! Thanks for you opinions!
[size=1.7em] beyerdynamic DT 990 Premium 32 ohm Headphones[/size]
[size=1.7em] beyerdynamic DT 860 Premium Headphones[/size]
[size=1.7em] Audio Technica ATH-AD900 Open Air Dynamic Headphones[/size]
[size=1.7em] V-MODA Crossfade M-80 On-Ear Noise-Isolating Metal Headphone[/size]
[size=1.7em] Audio-Technica ATH-M50 Professional Studio Monitor Headphones[/size]
Sennheiser HD558 (IDK how it will be w/out amp)
Denon AH-D1100 Advanced Over-Ear Headphones
[size=1.7em] Ultrasone HFI-780 S-Logic Surround Sound Professional Headphones[/size]
May 13, 2012 at 11:14 PM Post #3 of 14
You can rule out the HFI-780, AH-D1100, M-80, and possibly the ATH-M50 based on your preference in regard to bass, you can rule out the M-80, ATH-M50, and HFI-780 based on comfort, and if you want something portable you can rule out everything else on the list because it's open.
If you don't need a portable, closed headphones, I think the best bet for your preferences and limitations is the DT990.
May 13, 2012 at 11:32 PM Post #5 of 14
Op, why you don't list the musical genres you like?
Btw, the 558's will do fine unamped. (50 ohm impedance)
May 14, 2012 at 5:12 PM Post #8 of 14
HFI-780's.
May 14, 2012 at 7:11 PM Post #11 of 14
Out of your choices, I'd also go for the Sennheiser for comfort and ability to jive with much variation in genre. Since you're using them at home, the openness shouldn't be a problem.
May 15, 2012 at 7:42 PM Post #14 of 14
Heya,
Hifiman HE-300 revision 2 (new) would be a good option for you.
Very best,
Actually, having just heard the HE-300 for the first time last Saturday, I would have to echo MalVeauX here. I can see why HiFiMan has so many dedicated fans.
