Headphone Damage, Help !
Sep 17, 2002 at 7:25 PM Thread Starter Post #1 of 4
Ionixus
Hello !
I recently bought a pair of Sennheiser HD590's. They sounded great, untill today.
Yesterday my younger brother came in and knocked the headphones off my head. They then fell about four feet onto a hardwoord floor.
Since I couldn't see (or hear) any damage, life went on normally.
But today while I was listening to Beethovan, I noticed that the right side buzzes just slightly. I did several tests, playing different types of music and different volume levels.
Yes, the right ear does buzz. I have to turn the volume up a little higher than normal to really hear it, but it's only in the right ear so I know it's not normal.
Any ideas ?? I am sure it would take a volume level much higher than normal to damage the headphones. Also I would think that the headphones should be able to take little abuse.
Any input is appreciated,
-Ionixus
Sep 17, 2002 at 9:40 PM Post #2 of 4
Sounds like the diaphragms been crumpled...
I'm not sure if the bionetic Senns are as easily changeable as the older HD5x5 breed, but if you can get to the driver, i bet you'll see some damage there... with some patience it is fixable, but if it is crumpled, you're probably better off buying a replacement element...
