Nov 28, 2012 at 8:35 AM Thread Starter Post #1 of 4
roby456
Hi,
I have 2 headphones:
- Denon AH-D5000
- Sennheiser HD-485
I need to clean both. I was try myself in many ways without see any results.
Do you know if exist some good Headphone cleaning kit ?
If not exist there is some effective way to clean the pads of my heaphone (if possible without remove the pads)
Thank you !!!
Nov 28, 2012 at 9:57 AM Post #2 of 4
Damp lint free cloth to wipe the pads down also to wipe down the outside, you can use a mild soap if needed stay away from anything abrasive. Mini vacuum to clear the dust filters. Lint free cloth with a little oil to keep the pads soft.
Soft toothbrush to clean corners and hinges.
Lint remover to remove dust on velour pads. If they really need a clean then you soak them in soapy water and give them a clean. Allow to fry naturally. If they are still kinda hard, worn, etc, replace the pads. Not smoking near velour pads helps a lot.
