Oct 2, 2012 at 10:29 AM Thread Starter Post #1 of 8
AsadA203
Hi Guys,
Well I posted a while back about my X-Fi Forte analog outs dying on me so I have been forced to use the DAC on my Z5500 (from the digital out of the X-Fi Forte) to power my HD 555s.  I have personally found the Logitech's headphone out to be awful compared to the Forte's headphone amp (well, obviously lol) and I have been considering to either replace the X-Fi Forte with a new soundcard or get a USB DAC.
I am leaning towards the USB DAC because I can use it with my iPod and my Macbook Pro but I am concerned if I will be able to purchase one that will be audibly onpar with my X-Fi Forte.  So far, I was considering the Fiio E7 but I am open to other suggestions.
Thanks in advance.
Oct 2, 2012 at 10:38 AM Post #2 of 8
Hi Guys,
Thanks in advance.
For your computer you can get an Asus Xonar DG sound card, $20-$30.
A Fiio E6 for use with the iPod and Macbook Pro, $30.
Oct 2, 2012 at 11:03 AM Post #3 of 8
Hi Guys,
Thanks in advance.
Not all DACs can be used with iPod.
A DAC can be used with multiple sources.
Mention your budget for more suggestions.
Oct 2, 2012 at 11:35 AM Post #4 of 8
That unfortunately won't work as I don't have any PCI slots on my mobo, it would need to be PCI-E (also am looking for a headphone amp that is on par or better than the Forte, even though I don't think my HD 555s will notice that too much).
The Fiio E6 does look interesting though.
Below $100 for a USB headphone amp.  I am flexible on a PCI-E soundcard with a headphone amp, although I don't want another Auzentech/Creative product.
So is there a USB DAC/Sound card that supports ASIO?
Edit: I don't think the Fiio E6 will work since it only charges via the USB, it doesn't accept audio through it.  I would preferably want to bypass the analog audio out on a device like an iPod/Macbook/Galaxy S3 and get it right through the USB instead for no added distortion.
Oct 2, 2012 at 2:51 PM Post #5 of 8
There is the PCI-E version of the DG, called the DGX ($41)
You could always get the Essence STX for $180.
It $155 for an external DAC that works with portable Apple products and it's not really a "portable" DAC, for on the go.
I'm not sure you can bypass the Galaxies built in DAC, but I'm going to double check on that.
The Fiio E10 ($66) USB-DAC-Headphone amplifier should be able to work from the Macbook's USB output.
Oct 7, 2012 at 10:21 AM Post #7 of 8
Thanks for the info.  I think I will just go with the STX then, it seems to have a lot of fixes that the Forte should have come with and hopefully should last longer than my Forte.  I think I will go with the Fiio E7/E10 for my portable gear.
I am pretty sure the S3 can have the DAC bypassed via USB when I was researching it on XDA, that would definitely suck if I was wrong :(.  That was one of my big complaints with older Android phones.
Oct 7, 2012 at 1:51 PM Post #8 of 8
I've heard the newer Galaxy does have digital audio output with it's USB port.
