Headphone amp in my location.pls help
Jun 8, 2008 at 12:06 AM Thread Starter Post #1 of 7
knights
anyone from Philippines here (davao)? i tried all local audio-comp dealers but they have none...please help
newbie member,
KNIGHTS
Jun 8, 2008 at 1:57 PM Post #2 of 7
anyone?..... any member/staff/mods can help me to get one?... please PM me... THANKS
newbie member,
KNIGHTS
Jun 8, 2008 at 2:25 PM Post #3 of 7
Check the For Sale Forum here. Someone might be able to ship you one.
Have you ever used a soldering iron? You can always build your own, lots of people do.
Jun 8, 2008 at 2:33 PM Post #4 of 7
i think i still dont have previldge to post there... soldering iron? well, yes but i want those tested quality amps....
Jun 8, 2008 at 2:39 PM Post #5 of 7
You should still be able to buy. If you click the name of the seller, you will see an option to send him a Private Message.
As for building an amp, there are lots of designs that have been thoroughly tested and gone through by DIY people. The popular DIY amps are picked over more than the commercial amps are. If there are any problems with a design, it will be put on a message board or two and people will find a fix. A lot more eyes look at the DIY designs, which is one reason I think they're better.
As for testing of a particular amp, you can do that yourself! You need some test equipment, but you can make sure for yourself that it works well and won't cause any problems.
Oct 3, 2008 at 2:31 AM Post #7 of 7
did you get your amp already? i know a guy who makes good portable hp amps and is able to ship practically anywhere in the country i.e. Philippines
