MikeLa
- Jan 10, 2006
As long as you don't have an amp that outputs more than 70 w.p.c. then you won't need the box.
*Edit- Fang just called me back as I was typing this (I called him yesterday), and he told me that the impedance box and speaker cables will be ready in one month and the price will be +/-$100 give or take a Heineken.
In the meantime, the prodo HE-6 can be run directly out of any headphone amp that has a decent output. No portables, but certainly any amp that has minimal cujones (sp?).
Great! The Leben puts out 15w at 4/6/8 ohms (switch selectable).
Have you tried the HE-6 driven directly from speaker taps? Is there a hum?
I drove the LCD-2's directly from Leben speaker taps. The good, I thought it sounded better and the volume headroom was greatly increased - the bad, there was an audible hum. The hum wasn't terrible, but bad enough. When I ask Yoshi (Leben) about it he replied, "A resistor is applied between the output transformer and the headphone [size=medium]output to cope with headphone application, therefore, if you use a headphone directly from speaker output, there should be noise or hum. (It will not damage the amp, but is not a proper application)."[/size]
I don't understand how all this works, but I assume the resistor is needed because of the impedance mismatch - speaker output 8 ohms and headphone load 50 ohms - but that's just my uneducated guess.
