HE-400 VS HE400i VS Fidelio X2 (Need Input)
Jun 10, 2016 at 12:12 AM Post #77 of 81
Vonx
To be honest, Fostex TH-X00 probably kills all the headphones mentioned here. I would get that instead. If I wanted a planar, I'd get LCD-2.
At the cost of soundstage and midrange, though :frowning2:
I'm still looking for something that ticks all the boxes of the th-x00 does (bass quantity/quality, highs, intimacy) but has the soundstage of an X2 and the midrange forwardness of an hd650, and still manages to cost less than my car.
Jun 11, 2016 at 3:28 AM Post #78 of 81
TastyPastry
It sounds like you might have too high of expectations. Every headphone has its flaws.
That said, I think the only headphone I can recommend that might come close to your desires is the LCD 2 / LCD 3, although I'm not sure how much your car costs
Jun 12, 2016 at 5:10 AM Post #79 of 81
Vonx
You're probably right. I figured that. The fa-011 basically is that headphone except that it doesn't have quite the clarity the X2's have, but its easy to get over :D It would be nice if there was a direct upgrade to the fa-011 under $500. The x2's are a slight upgrade in clarity but have a huge dip in the mids which really sucks. The fostex apparently have the same problem. EQ helps a lot though
Jun 13, 2016 at 7:09 PM Post #80 of 81
mkarikom
what gear were you using with the x2?
Jan 21, 2017 at 1:57 AM Post #81 of 81
Phillay
Soooooo...I may have done something stupid. I'm also new here and new to the Head-Fi community so hi everyone! I just started getting into mid-high end audio VERY recently and saw a couple deals I couldn't pass up on. There were a pair of brand new in box HE400i with the new connectors on ebay with free shipping for $329.00 Canadian and someone locally selling a pair of HE400 like new with less that 10 hours for $180 Canadian so I ended up buying both since they were less than half of what they normally cost. Should I have done that or am I an idiot for doing so? I'm also looking at the Schiit Magni+Modi V1 stack to power these cans. Can anyone provide some input or advice?
Thanks!!!!!
