It is more realistic to expect audible improvements with upgrading your dac and amplification to the highest level possible, than expect improvements by raising sampling rate or "resolution". Using 44.1 kHz is not an obstacle for the highest quality reproduction with the most expensive gear available. All experiments and tests show that the transition from 44.1 to 96 kHz is almost non audible by absolute standards, (using any gear) while the transition from a $/€ 300 dac to a €/$ 2000 one is very dramatic. Compliment your best headphones with really top electronics (if possible) and listen for your self! The "bottleneck" is never the sampling rate; it is the dac/amplifier and the quality of the recording. However, almost any recording will benefit from high quality gear.
No need to say that 192 kHz is absolutely not needed for the highest sound quality (as percieved by human hearing), though it can facilitate the work of recording and mixing/mastering engineers.
I did upgrade my dac from a $300 one to a $2400 one, actually. Yes, my new 44.1 smokes anything my old dac could do. Now, I can easily tell any changes that happen with my system. The problem with 44.1kbps tracks, is that every time there's a sample, it plays that sample until the next one comes. It's like listening to sound that's full of gaps. 96kbps sounds like it doubles the rate at which new information plays. It's the right improvement to make, but 96 leaves something lacking, that 192 satisfies better. The difference it makes is still not as big as using the best player, either. Using the default Amazon music streaming app playing 192 won't sound as good as Audirvana playing the same track at 44.1 from somewhere else, but it will sound like the original copy has more samples, and seems less full of holes. Getting 192 in Audirvana is really my hope, I can get that now with Qobuz, and if Tidal drops their MQA scam, I will be able to get it from Tidal. Otherwise, 192 will be the improving factor after all other considerations are the same, because it is the original recording quality measurement. You are, however, correct that it won't produce more bass, which is the thread's subject, only improve the amount of information everything gets. I only meant that my desire for more bass had been met, and that sample rate was all that was left to look forward to.
I have upgraded every inch of my chain to something better, except for the actual usb port my pc is outputting from. If your pc is plugged into a cheap power bar, get it off of there, for a major improvement in soundstage, clarity, and depth. Same improvement happens with video, getting off of a cheap power bar. A better cable on the pc further improves the signal that it is digitally outputting, I'm assuming you already know to do this on all the rest of your a/v equipment, with your amp straight into the wall for biggest soundstage, and unrestricted power except for your neighbor's noisy fridges.
Anyways, the 800's bass is supposed to be the thread's subject, so wow, I have huge full bass with my setup. Sonarworks was already the cat's pajamas back on my old $300 dac, but my new dac showed me that the bass hadn't all been playing. Now, it seems like every sound has more bass, even violins. The extra bass with violins makes it sound like I can hear the wooden body of the instrument, and makes it seem much more like it's actually a real violin playing. However, I would like to be done with upgrading my gear for a while now. I don't want to listen for bottlenecks, and I don't want to think about the 10k dac that people say is better than mine. Amazon is sending me a $60 tube for my amp, that may beat the $10 stock one, although will probably not be as good as the $250 tube I got when I first got the amp. I hadn't upgraded too much of my chain back when I was using that, so it's performance probably didn't even show as well as it would now. But, Sonarworks is the thing that fixed my eq problems, which no dac/amp combination would be able to correct to a flat line. If dac/amps could be incorrect enough to make HD800's flat, there would be major problems with dac/amps. It's a good thing frequency flaws are mostly only speaker/headphone problems, though they can be really bad, like the original 800's.
Sonarworks fixed my bass problem more than any of these changes is gear, though. Bass from the gear improvements is nice too, though, and is not the same way that adding a 4db bass boost sounds, so you should probably just buy the most expensive amp and dac that there is, and the fattest 8N purity power/signal cables you can find. And the 1500w max power conditioner for everything before your amp, which should go straight into the wall, I bet you'd still like a dedicated run for your outlets to the circuit box. Then, you'll want your home to be isolated from all your neighbors, and a straight run to an even bigger nuclear power plant. Oh, and there's this re-clocker you can output to, it also has an external clock upgrade port, that they say outputs a much better sounding I2S signal to your dac. Listening to the sound of my new dac's improved clocks, which cost almost as much as the $300 dac, I would love to have a better clock, that part keeps it from sounding totally fake. I never hear any digital that is clocked better than mine, the rest all sounds jerky. Clocks won't change your bass, though so that's ot.
