HD800 S fraying cable advice
  1. smodtactical
    My HD 800S is 2 years old and the cables keep fraying, I keep putting electrical tape on the exposed areas but now 1 side is cutting out depending on how i bend the wire. So now I am thinking of either a cable replacement or upgrade to a balanced amp and use my included balanced cable.
    Write now using a burson conductor SL 9018.
    Any suggestions? New SE cable or upgrade + use balanced cable?
  2. Whitigir
    I always use balanced cables where possible. So upgrade the cables seems perfectly reasonable
  3. smodtactical
    So your saying upgrade my amp + dac to one that supports balanced?
    If so any recommendations for something that would be a good step up from burson conductor SL ?
