wgr73
- Mar 19, 2007
I'm re-terminating my HD595s to have a 3.5mm plug. The cable is cut, and the wires are ready for tinning, however, the wires will not tin...solder will not make contact with them; it just rolls off. I noticed the HD595 wires have small fiber inside with the wire. I am using radioshack rosin core solder. HELP
This can be a big problem ....
EDIT: I noticed that the solder Sennheiser used on their plug cools very quick. Could this be my problem?
