1Time
- Jun 1, 2005
I agree. 1/2 ounce of tack definitely seems like too much to me and 1/4 ounce likely would prove to be too little.
Being aware these wires can detach, I was fairly careful doing this mod. And I was not aware of having done something to cause it to detach. I suspect the wire detached simply by having been moved too much, kind of like when you bend a wire back and forth enough times it then breaks in two; the wires are very thin and seem very susceptible to breaking at the solder joint. I probably would not have had this problem had I done this mod right the first time.
I have a soldering iron, but I likely will take it to a local shop for repair. I'm just not in a hurry about it since I now use my Ultrasone Proline 650 to listen to techno / trance instead of my HD280. And with now owning my 2 other new Senns, my HD280 is practically out use now. I enjoyed it very much for a couple years even before trying this mod.
Originally Posted by threEchelon /img/forum/go_quote.gif I guess this should be a warning to prospective blue-tack modders: Don't overfill or at least avoid the area near the driver solder posts! |
Originally Posted by threEchelon /img/forum/go_quote.gif Maybe there is a head-fier that lives near you that could repair your phones. In fact, anyone with a soldering iron could do it; just find some one who has one. |
