Maxvla
- Dec 26, 2002
Yes that is true along model lines, but not for single headphones, generally they will follow a trend you can check by reading on this forum. Like I mentioned before most people will suggest a tube amp for HD600/HD650, which means that these don't mix as well with solid state amplifiers until you start getting into the very high end exotic solid states.
One thing about high end gear is that sometimes the designers have a particular sound they want and it may be a bit off the beaten path so you can certainly have a multi-thousand dollar amp that just doesn't match right with a certain headphone model.
I suggested the hybrid 1+ partly because it is just $109 and partly because you need to get experience with an amp of any kind before you are informed enough to pay more. Long ago I bought a $400 solid state amp for my HD580 (similar to HD600) and I really couldn't tell a bit of difference. I thought amping was bogus and never touched one again after selling it til about 5 months ago when I got my Little Dot MKIII tube amplifier which totally wowed me. Now I'm sitting here with the top of the line MKVI balanced tube amp waiting on some cables to come in so I can fire it up. So you can see from my experience that you simply need to try things out.
Another thing to consider is that if you stick with relatively popular models you see on the forums there is a good chance you can sell off something you don't like or you've upgraded past in our for sale forums and get a good % of the original cost. Many (more wealthy than me) people take a shotgun approach to gear, they'll buy 3-4 headphones, amps, cables, digital to analog converters, cd players, etc or a mix of the above and just try everything and sell off what they don't like later.
Originally Posted by Goit /img/forum/go_quote.gif Is it true that headphones are picky about amps for no reason? Like you can get a pricey one and it just doesn't sound good for some reason? Because since I'm ordering off the internet, I'm not going to be able to try it myself. |
