Braver
Will upgrade headphoneswhen there's a MX600.
I have this weird problem on this computer, mainly with InCD and MemTrax, where the 'skins' they use for the windows don't fit.
with Memtrax everything is out of whack, with buttons floating outside the window and text not fitting what seems to be the designated space.
with InCD it's similar. you get the regular grey pop-up that Windows uses. and they drop a picture on that, with buttons and text, but skin is too small, again with text falling outside the skin.
wait, I'll try and add a picture..
anyone familiar with this problem? is there a cure?
stats on the comp: Dell 4100 laptop, 800mHz P3, WinME, 128 Mb RAM, Ati mobility at 1024x768.
