Gustard X26 III First Impressions
Unlike its predecessor, the X26 Pro, the X26 III is a combined DAC and streamer. It also uses the later ES9039 Pro chipset, as opposed to the ES9038 Pro of the X26 Pro. This chipset claims lower power consumption and improved performance.
I won’t repeat all specifications here, except to add that the I2S input is now configurable for different standards; the streamer can use UPnP, roon, HQPlayer, Spotify, MConnect and AirPlay protocols and has a direct browser interface; there is a new clock synthesiser module GCLK-02 (the older DAC had a K-2) which still accepts an external clock, and the whole unit is wrapped in a stylish and attractive metal case.
Dimensions are the same as the X26 Pro and it weighs 7kg.
Preparation
In preparation, I swapped in my SR Purple fuse from the previous DAC to the rear panel holder. I also temporarily connected it to ethernet, set it to Streamer and browsed to
http://x26.local, or at least I tried to but somewhere along the line DNS didn’t see it. No matter, I checked my devices connected to the network and found “CelAudio” which turned out to be the Gustard, then browsed to the IP address. That brought up the interface immediately. Next issue: the interface displayed in Japanese. I found the language setting and changed it to “Egnlish”. Clearly some firmware updates will be forthcoming. I then “Stoped” all the running services to ensure that evaluation as a DAC would be as pure as possible.
Just before that, I left UPnP running, fired up Bubble, pointed it to “UpMpd-X26-UPnP/AV” and played some different tracks at different resolutions. Confirmed, the Gustard is playing them and displaying the correct resolution. With that done, I turned off UPnP and moved the Gustard to the music room.
System Setup
• Incoming I2S from my Gustard U18 is from a Tubulus Argentus I2S cable. This also carries the clock from the U18 and its external clock, an AfterDark Emperor Triple Crown
• Analogue output is to a pair of Coherent 6D Gen 2 phono cables
• Power is provided from a Coherent 6D power cable, from a PS Audio P3 regenerator
• Fuse is an SR Purple
• The Gustard rests on four Black Ravioli Plus footers, then on an Electric Beach S1NX support platform, which is itself on RDC Cones and Cups onto a Black Ravioli platform
• Digital filter set to Vivid (unlike the X26 Pro where I prefer Gentle)
First Listening
By comparison with the X26 Pro, there is an immediate sense of a tighter grip. This I think is in the upper bass area but it makes grunty songs like Lorde’s Buzzcut Season (24/192) really stand out. This additional grunt is confirmed with Alt-J’s Dissolve Me (24/96), the song showing its dynamic range from almost dead silent to full on with realistic power. It’s easier to hear the separate voices, too.
The bass in Kiss in Blue by Yello (16/44) is potent while not modulating Heidi’s voice and all the percussive sounds at all, the soundstage remaining as clear as ever. This is how Yello should be played, with the rhythm coming through strongly, underpinned by growling bass. Continuing with the bass, my favourite recording of the Durufle Requiem, with Shaw and the Atlanta SO (16/44) features some extraordinary organ pedals and they are rendered with the foundational impact only a large organ can convey. Also, the massed choir of voices (the single most difficult music to reproduce without becoming a mess) is rendered extremely clearly and sounding, well, like the real thing. Very good for a standard resolution recording.
Turning to Samuel from The Mountain Goats (16/44), this is another dynamic range spectacular. The opening cymbal’s clarity is telling and the drum has great impact while the guitar continues strumming.
Continuing with dynamics, there isn’t much to beat Chris Isaak in Baby Did A Bad Bad Thing (16/44) when he fully lets rip.
Back to voice quality, Greg Laswell’s Dodged a Bullet (24/96) has a nice gravelly texture while PJ Harvey in To Bring You My Love (16/44) works vocal wonders around an extremely crunchy guitar. There is more fine detail in the light strumming sounds, giving it a more metallic edge, too.
Some live music to assess realistic portrayal of a live event and how could I start without Hawkwind’s Down Through The Night from Space Ritual (24/48)? This was an absolute mess on LP but it has improved as my system has improved, the hi-res stream bringing the performance from 1972 to life. The Gustard is delivering it so well I wish I could travel in time back to that event. Natalie Merchant and Carnival (16/44) next and another great concert recording, conveying power but also her characterful voice. Then the obligatory Nils Lofgren and Keith Don’t Go from Acoustic Live (16/44) and a wonderful rendition of his live guitar sound, especially the complex bite to the strings. Incredible attack! Finally, and remembering one of the finest concerts I’ve ever attended last night, the LSO Live recording of Stravinsky’s Rite of Spring (24/96) is a decent attempt at reproducing that visceral music here in my room. Here, with classical music, the X26 III is showing a clean pair of heels to the X26 Pro, really pulling ahead in realism while handing huge complexity and dynamics without becoming harsh or muddled.
The management summary so far: the X26 III is subtly better than the already good X26 Pro in virtually every area from fine detail to dynamics, soundstage, low level background, note decay, bass power and texture and lack of harshness. This is a very good performance from brand new.
The above Impressions are with just a few hours on the DAC. I’m sure the next few hundred hours will add more goodness and I shall help it along with some Tara Labs burn-in signal overnight. I also have the streamer to try at a future time, but I probably won’t do that until the DAC’s performance has settled.
