Gustard X20 DAC
Feb 13, 2016 at 5:40 AM Post #436 of 1,320
Thanks! Those boards look interesting but I use two embedded (SOC) types, which I like.  PPA card too.
Trouble with 'computer audio' is that there are so many variables affecting the sound, it's difficult to know what's causing what
In any case, the X20 seems to appreciate a good level of transport (be it CD, PC etc) and amplification.
Have you tried with a laptop running out of the battery?
Feb 13, 2016 at 10:02 AM Post #438 of 1,320
  "Ok somebody hid a turntable in my room - and a darn good one. But where is it?" :)
 Roberto
This is my first DSD DAC and that was exactly my reaction.  The treble peaks that so easily offend in PCM are simply not there (buckets of headroom).  With PCM I'm always dressing up the source with the right combination of accoutrements (cables, filters, psus) to tame those pitchy notes.  For brighter amps+speakers you'll need more (or darker) accoutrements for the dial in.
The real punch in my stomach was when I heard MP3 converted to DSF.  The improvement was undeniable and implication terrifying.  If I'm going to batch convert my entire library to DSD then I need a plan:
1) Is there playback software or a DAC (like PSAudio's DirectStream) that can encode DSD in real time and match what I'm hearing from the DSFs created in JRiver?
2) If convert I must, then I better be damn sure I'm using the best software for the job (I read SoX is better than JRiver)
3) perhaps the upsample should be a function of the source (ex: DSD64 for 16bit, DSD128 for 24/48, DSD256 for 24/96+)
4) Should I store it side by side with the original media, or does it get it's own drive? Should I move all my DSD stuff to it's own drive (ISOs included)?  I'll need a folder naming strategy to disclose the original format.  ex:
Abc - [2015] Xyz.FLAC24192
becomes
Abc - [2015] Xyz.FLAC24192_DSD256
Feb 13, 2016 at 11:09 AM Post #439 of 1,320
  Four weeks in and *finally* getting some good sound out of the damn thing. That's after changing over to dual PC's linked together with fibre optic cards, cables and a switch (the latter arrived yesterday).
Evidently my single PC wasn't cutting it previously because there was a warm colouration and a cloudy forwardness that didn't sound particularly linear. It's now dramatically more open and clear.
The X20 is a fine tool for telling you all about the rest of your system downstream. The bad news is that it needs to in order because the DAC will tell you all about it
Interesting stuff ...
I was thinking about building a little dedicated audio PC round an
ASRock N3150T Quad Core USB 3 Mini ITX Motherboard. Mainly because
it's easy to power from an external linear power source. Then adding
a PPA (or similar) usb card to it as well.
Now I'm wondering if the Intel N3150 1.6 Ghz chip may not pack enough
horsepower to run everything 100% smoothly ? It manages 1584 on PassMark.
What SoC's are you running ?
On my i7 system cpu use rarely gets above single figures when running foobar.
Which is why I thought something like a N3150 based PC would be fine, despite
being 4 or 5 times less powerful.
However, it does seem strange that you got such an alteration in the character of
the sound. I'd have thought you'd get clipping and stuttering rather than an
actual change in the quality of sound if there were processing issues.
Then again computers often seem to have a random and very frustrating mind
of their own at times, as I'm sure we've all experienced on various occasions !!
Anyway, I'm glad you're finally beginning to enjoy your X20
Cheers
Simon
Feb 13, 2016 at 11:45 AM Post #440 of 1,320
Foobar2000 up-samples MP3 and WAV etc to DSD on the fly.
I spent some time up-sampling everything to DSD 256, and it definitely
smooths out the sound.
However, when A/B'ing vocals between the up-sampled DSD and the original
PCM copies, I did notice a distinct change in tone and emphasis.
On some tracks I prefered the DSD version, but on many others I actually
much prefered the original PCM version, and so no longer have upsampling to
DSD set as my default.
It's great having the option, and definitely suits some tracks and musical
styles, but to 'my' ears is no panacea.
This only relates to my experience with upsampling to DSD. Not DSD originated
material.
Cheers
Simon
Feb 13, 2016 at 12:48 PM Post #441 of 1,320
material.
Cheers
Simon
What you described is one of reasons for a group of people against up-sampling.
Feb 13, 2016 at 2:15 PM Post #442 of 1,320
Hi. For a single PC, the N3150 will probably be powerful enough, as long as your chosen software isn't too demanding on system resources. I run a Q1900 and N3150M with JPLAY/ Minimserver/ Kazoo, typically only using around 1% or 2% CPU while playing music. I would definitely recommend W10 if using windows. Feel free to PM me if you need any help or tips, although I only have recent experience of the above software (and foobar)
http://www.computeraudiophile.com/f10-music-servers/embedded-style-motherboard-good-bad-idea-27562/
I agree, especially considering the same single pc was then used as the audio pc in my dual set up. My take on it is that the X20 is really accentuating the benefits of dual pc streaming, fibre optic ethernet (for galvanic isolation), plus the optical switch (with its clock). Still doesn't fully explain why the audio pc (when used as a single pc) provided such a coloured and pushy sound through the same active monitors.
I think this DAC is very revealing regardless of source.  There was a noticeable SQ difference when housing the same motherboard in two different cases the other day
It's a weird trip, let's face it
Feb 14, 2016 at 9:58 AM Post #443 of 1,320
I like the sound of this.  Devialet was citing isolation as one of the advantages of going wireless but I prefer the lower latency and higher bandwidth of your hard wired solution.
So I tried to research this own my own, starting with newegg where I saw reviews going back to 2004.  I was embarrassed to discover MOCA devices 6 years after they came out, but this is even worse.  Can you share links to what you use?
This one Trendnet listing let's me compare the newer+smaller+costlier LC/LC connection (100/1000 SFP) vs the older+cheaper SC/SC connection (550M)
http://www.amazon.com/TRENDnet-Intelligent-1000Base-T-1000Base-SX-TFC-1000MSC/dp/B00008NV11
Looks like $160 to wire up LC/LC and $116 to do SC/SC
Feb 14, 2016 at 12:12 PM Post #444 of 1,320
I recommend:
2 x TP Link 220L Fibre Media Converters
2 x second-hand Cisco SFP's (GLC-LH-SM  30-1299-01)
1 x LC to LC, OS1 9/125 singlemode duplex fibre cable
The best resource and place to ask questions is the thread on CA:
http://www.computeraudiophile.com/f22-networking-networked-audio-and-streaming/optical-network-configurations-24641/
http://www.computeraudiophile.com/f22-networking-networked-audio-and-streaming/network-isolation-4265/
Feb 14, 2016 at 1:40 PM Post #445 of 1,320
ugh, so much to learn
why you single-mode over multimode
why use 9/125 over 62.5/125
why use the TP-Link converter with a used Cisco transceiver instead of the $35 TP-Link under amazon's "Frequently Bought Together"
how long before iFi sees this thread and build's an all-in-one device that look's like their iPurifier with female RJ45 ports on each end
join me on my trip to computeraudiophile.com where I'll uncover all these answers and more...
Feb 15, 2016 at 6:04 AM Post #446 of 1,320
Hi guys, sorry for my bad English.
I am happy owner of Gustard X20, this DAC for me has extraordinary price performance ratio but compare with Aqua La Scala Mk II, obviously La Scala It is much better on all parameters.
However, this is not the reason why write this post.
Yesterday tested the I2S input with Raspberry PI 2 and ODROID C1 plus... nothing works.
I tried:
- www.runeaudio.com
- www.moodeaudio.org
Tried ODROID C1 plus HDMI on board and I2S Kit Audio GD and Raspberry only I2S Kit Audio GD accordance to pin instructions.
Everything works well with PS Audio - Raspberry - www.moodeaudio.org  (here a photo: http://www.hifilibre.it/forum/viewtopic.php?f=20&t=527&hilit=mac+mini&start=30 )
Anyone of you did play Gustard X20 I2S input ?
Thanks in advance.
Feb 15, 2016 at 7:12 AM Post #447 of 1,320
Feb 15, 2016 at 9:24 AM Post #449 of 1,320
Ciao!
... and ... I think what you are saying should be expected. Several people here have directly compared the X20(U) - mind you, a ~800 EUR component - to DACs costing 3-4 times as much, and in many cases preferred the Gustard.  But If I do not err the Aqua La Scala Mk II costs nearly 5 thousands EUR, and it is known to be an excellent DAC (John H. Darko considers it the best DAC he auditioned, and the list of DACs he reviewed is quite impressive).  That is sounds better is not necessarily expected - nothing is obvious in the world of audio - but I am not surprised.
Do you own it? In that case I should pay you a visit next time I come to Italy :)
 Roberto
Feb 15, 2016 at 9:34 AM Post #450 of 1,320
 Roberto
Ciao Roberto,
I would be grateful if you sign up to our forum www.hifilibre.it it's difficult for me write in English.
If you want to listen La Scala, Meitner DA-1, Merging Hapi no problem.
PS: Thank's Head-Fi forum hospitality.
