Very interesting devicу this Gustard U12:
"Newest XMOS chip and uses 48MHz oscillator to asynchronous reclock usb audio data to I2S line, old XMOS uses only 13Mhz oscillator, over 4x better jitter rejection theoretically"
Display, PSU inside, AES/EBU, i2s , opt and coax and Built-in smart switch, plug in USB automatically!!!
But Digital Transformer Pulse PE-65612NL (limits 7 mbps 96kHz)!!! it is necessary remove and istall Murata DA101C!!!
P.S.
Full Technical Parameters:
Laser marking, never fade
Two 0.1PPM precision crystal 45.1584M 49.1520M
International voltage AC115V-230V, the need to manually adjust
Rigorous design, reasonable layout, elegant lines, solid materials.
Figures show that a mesh understand. DSD support 128, PCM supports 384K
Aluminum chassis, the drawing process, the body all black, black and silver optional panel
XMOS - U8 chip, support 32BIT / 500MIPS digital signal processing unit, the inside has eight cores.
Interface from left to right are: power input AES / EBU output coaxial output IIS output optical output USB input
Machine size (not including protruding parts): Width 160mm × 50mm × depth 120mm high
Package Size: Width 225mm * 80mm * Deep 190mm high
Weight: Net Weight 1KG, including packaging 1.3KG
Features:
Increase the screen display, the sampling rate at a glance
Use XMOS programs to support 32B 384khz asynchronous 2.0 (USB recommended that ASIO output)
Using an independent power supply. Built-in sealing ring cattle, multiple sets of multi-level regulation. About the importance of independent power, I believe we all know.
Optimize the design of the audio clock circuit using 0.1PPM precision active crystal to provide a more perfect clock signal to digital audio. Provided for by the two crystals were 44.1 / 88.2 / 176.4 / 352.8Khz and 48/96/192 / 384Khz series rate signal only after the selected clock rate selected work, work another one audio clock stop, put an end to the mutual interference may bring work simultaneously when the two clocks.
A total of four kinds of output: Coaxial (RCA), optical fiber, AES / EBU, IIS (HDMI port)
Coaxial fiber AES / EBU output formats IEC60958 and AES3-r2009 standard limits the maximum support 24Bit / 192kHz; IIS can transmit 32B 384K
Smart switch, USB has a current interface to boot. Interface with the computer switch and switch machine (computer to be set off USB power failure), or unplug the USB cable directly to the shutdown.
Description
Gustard U12 digital interface XMOS program complete independent linear power interface 0.1PPM crystal support 32B 384K
U12 uses the company used in professional audio field XMOS latest chip U8, inside there are eight cores, with powerful multi-core multi-thread processing capability, is the industry's very good USB Audio Class 2.0 digital audio solutions.
