mandrake50
- Aug 13, 2007
Yes, conductive material loose inside an electronic device is not a good thing. I have to say that using 3M thermal tape I have not yet had anything come loose. I have used for heat sinks on video cards. One time I tried to remove the memory sinks from a card to get a warranty replacement. I pulled the sinks (first one) off and the case of the IC came with it. Of course you can do better with the best grades of thermal epoxy, if it is applied correctly.
That FLIR TG256 looks like a fine device. I am tempted to pick one up myself. Beyond electronic temperature measurement, it would be good for HVAC and other things that I do. I like that 30:1 spot ratio.
Well, keep us posted. I am quite interested in your results.
BTW, not sure whether I mentioned it. I did order a full set of the Burson V6 opamps to try (along with a Conductor V2). There have been some delays on that, but hopefully I will get them next week some time.
