MLegend
- Feb 10, 2014
Still waiting for mine as well.
Here is a treat for hi-def junkies here:
http://primeseat.net/en/
Long story short, you can listen to selected dsd64/dsd128 recordings there for free as long as your DAC supports it.
You will have to install their free app, they have got version for either Windows or Mac (no linux support, boo).
I especially like their currently available "The 10th anniversary live concert of the Blue Coast Records St. Valentine Day's" Part2 (Alex de Grassi). Amazing acoustic guitar work.
Now, here is interesting (and relevant) part.
I can hear a difference in dsd128 - it is SO MUCH better than either dsd64 or 196/24 - but only when I listen on my KEF LS50 loudspeakers - ambiance, depth and detail are simply unreal, it is not a subtle difference at all. dsd128 is simply jaw dropping.
And dsd64 to me sounds not any better than 196/24 (and if I understand technical details, it probably should not).
But alas, all my headphone gear, including H10, is unable to reproduce that difference of dsd128. Even BH Crack, while usually a bit better on the ambiance part, is blind to those differences.
I mean, dsd64 sounds same as dsd128 and 196/24. And dsd128 is a bit better than 96/24, but difference is rather small.
And neither T70 nor 400i cuts it.
And here comes my plea...
Could somebody with a full boat give this a try? Wondering if upgrade improves resolution of H10 enough to hear that difference.
Strongly not recommended
In case you really want to do this, then:
- you'll loose Burson's life-time warranty
- it will be very difficult to remove existing red plastic housing because of internal yellow molded thermal compound
- short circuit might occur if external aluminum/copper housing will get installed
For those really needing an external copper housing then have a look at BURSON SS website because there's already a copper housing made especially for the V5 SS opmaps, but it needs to be properly grounded (no need to remove existing red plastic housing). It's been designed to minimize external EMI/RFI noise, so it's basically a copper shield to minimize noise injection.
It is like comparing apples to oranges. Also headphones and loudspeakers you are using for this comparison are from different leagues.
The photo at the Burson page looks as if it's nothing more than sefl-adhesive copper foil - which is fine, but I don't think it's in anyway more special than that. My fear is that it might keep some heat inside the V5 while it keeps some EMI/RFI out.
http://www.amazon.com/Fly-Young-Copper-Conductive-Adhesive/dp/B013GEWN8I
http://www.ebay.com/itm/GUSTARD-H10-High-Current-Class-A-Discrete-Output-Headphone-Amp-/252160495389
Anyone bought from this seller ?
i am between Lake people G109-A and Gustard.
Gustard has better design (on papers) but the g109 is almost as capable in amping ,with great build quality and warranty support.
Never seen an official site for the Gustard
Any bad quality issues for the Gustard that i should now about ?
Get the Gustard, you won't be disapointed. It is on sale at Massdrop.
https://www.massdrop.com/buy/gustard-h10
