firstwat
- Mar 30, 2013
Will do my best to test as you mentioned as much as I can, preferably using some other cheaper cans also. It will help highlight the differences very well.
I think I can find some powerful gears there as well....
Thats great, make sure you test cheaper headphones than 990's or 770's as well to hear the differences, because depending on what kind of soundcard your laptop has, you might not hear a great difference. Also, if the store has some kind of hi-fi gear inside, such as receivers, speakers amps, etc....ask the seller to let you hear it from those sources, so that you get a more realistic feel of what these headphones can do, they will both get powered perfectly by any such device.
