Grounding - How to?
Jun 27, 2009 at 10:27 AM Thread Starter Post #1 of 5
DuCKy!
Hi guys,
Just starting with a bit more DIY without tutorials and whatnot, ie. schematics only.
As far as grounding is concerned, how should I do it? I'm attempting the acoustic simulator from CMoy and trying to figure everything from the schematic.
From his portable amp design, which I did off tangent's tutorial, is just the virtual ground created by the resistors.
What about the acoustic simulator?
Where do I ground the 2x Resisters and Caps, + the jacks to?
Any help is much appreciated.
Regards
Nick
Jun 28, 2009 at 1:07 AM Post #4 of 5
DuCKy!
So I can just solder them all to one isolated strip on the protoboard or something?
So they have to be in series with each other or?
Or can I just solder them individually to any random isolated place on the protoboard?
Jun 28, 2009 at 2:36 AM Post #5 of 5
JamesL
Yes.. Just connect them all to one isolated strip on the protoboard that will act as ground.
You can't really connect them in "series" since they're all connected to the same ground plane.
