music_man
- Jun 6, 2005
i have been testing this the last few hours and i feel the verdict is in. i have used almost every usb audio tweak. i had just tried the ps audio lanrover to no avail. i was back to an audioquest jitterbug to a uptone regen, with js-2 lps. the uptone is really just a very good hub. better than the vaunix. now i discovered the startech ST7300U3M. oddly, if you cut the vbus it will not operate. what is special about this is it operates on 12 volts and a ti regulator steps it down to 5v. than another ti cascade regulator steps it down to the 3.3v per port. i have a audioquest jitterbug in front of it. audio quest diamond cables. it is powered by the uptone js-2 at 12v. 12v is the key here to the clean data and power. i measured 126db noise floor. the highest i have measured so far. lan rover was 116db and the regen was 119. i cannot use the microrendu because i am not using a compatible host program. namely jriver. i found running this with fidelizer made no difference, so it is very clean. the background is dark black silent. the highs are much higher. more extended bass. better imaging and soundstage than anything i have heard yet. if you saw this, it is built better than the vaunix. the internal components are the finest. best diodes,vishay resistors, rubycon caps. amazingly this can be had for $49 but usually about $52. solid modular billet aluminum chassis. comes with sorbathane strips to stick on for feet or a plate mount. the included smps is very high quality but not the jp-2. i am very happy with this. sans microrendu this may be end game in this system. i just do not understand why i cannot cut the vbus or it ceases to operate. it will run unpowered at low draw but has a relay that cuts vbus if a psu is present. i had asked about this earlier with no replies but took it apart and got my answer. it also has linear regulation inside so the js-2 may be redundant to some extent. i have not tested the included ac brick. the js-2 is obviously better but if it makes a sound difference i do not know as of now. so perhaps without the js--2 you have $52 for the hub and $49 for the aq jb. however i have about $5,000 of diamond cables. if you do not want to spend that i can recommend cardas clear which is a fraction of the price and 90% of the diamonds sound. this might be the best usb chain yet and without the js-2 and diamonds it is very affordable. startech is known for their hidden audio jems. the gigabit usb etherrnet extender rex/lex is very good but i feel this is better and does measure better. i am extremely impressed with this. i do not know how much of it is the js-2 and diamonds but they certainly contribute. i imagine you can get close for just the $100. i have tried ifi ipurifier with isub3.0 and w4s rur. they were not as good as this imo. on the other hand for just the $100 you don't have much to lose. as it is returnable anyways. i plug 1 gigabyte usb sticks in the remaining slots which in this instance is the best way to play your audio, again imo. this has been studied though. i feel this may be end game for usb at least. btw, the regen and rur are just very high quality hubs and this is higher quality than those. this is designed for industrial use.. you can be skeptical but as i said startech is known for their hidden jems that just happen to have audio applications. i did not find the conversion to ethernet was better and back to usb. it seems something is lost. probably data in fact. even though it is gigabit vs. 480mbps it cannot support the full scale of usb 2.0 such as dsd 8x. which should tell you something right there. so i gather from those limitations there are others. as in sound. i would stick with one data format and not introduce conversions. even though others feel this sounds better. i found others that did not feel the lanrover improved sound. if anything detracted from it. only microrendu is better but i am not using roon. this is because it is something different entirely. it is not conversion but a tiny computer all it's own. i have tried it though. this is not meant to be a thread like "ultimate usb chain" as this is solely my opinion and i admit that. i just wanted to relay my experience. i still do not know why i cannot cut vbus but rest assured it is disconnecting with the psu present anyways. i just wished to share my findings, because to me at least they were very positive. the best i have heard thus far. of course this is just my opinion. ymmv as always
