BootsandPants
- Nov 3, 2011
You can check out the Project Ember Tube Rolling thread. I'm using the Project ember II with dual Zenith 6J5 tubes with my GH-1.
Sent from my Nexus 5 using Tapatalk
Cool; thanks for the pointer; I'll have to take a look at that. Does it ever end?
Welcome back. The more knowledgeable people have been neglecting to answer so I'll pop in to say what I've learned.
While I've not been able to hear all of these, the most common recommendations I've seen for these will depend on your budget of course, but what I'm seeing recommended more than anything is a Schiit amp/dac stack or some combination of gear from Woo Audio.
The particular stuff you get will of course depend on your budget. The Schiit Bifrost/Lyr2 combo runs about $800-$930. Woo Audio gear is more expensive and more like 'endgame' gear. They have options from cheap to (very) expensive based on what you'd want to spend. The WA6 gets a lot of praise. If I had $2k to spend on an amp I'd get a WA22. It's super badass. That's not including whatever DAC you go with.
Honorable mention: If you'd want something that's less expensive and portable, check out the Chord Mojo. It's $600 retail.
By the way if you want specific advice on amplifiers I'd check out the amplifier forum. Good luck and happy hunting
Thanks for the recommendations, but I'm already running a Modi2 Uber into a Garage1217 Ember II, so I'm pretty set so far! Not quite ready to take the jump into $$$ amp/dac. Was more looking for tube specific recommendations, but this is good advice for someone else looking for an amp or dac.
That's the cool thing about the Ember; super easy tube rolling, auto-bias yadda yadda. Just plug and play different tubes to change the sound! Been loving it so far, and the price is right! Works well with my Grado and Audeze cans; it's a really neat piece of kit
