scootsit
- Oct 23, 2011
On the wood ones, I think they use wood glue.
Have you tried hot glue? I think that's what Grado is using
i once modded my RS2's to get more bass, as i prefer to use G-cush pads, however now the drivers aren't glued to the cups anymore.
does anybody know what glue was used by grado?
Thanks for the info! I'm still debating should I liberate or not... The final answer shall be released in a few hours xD
^ I'm using his xD
@jaywillin Just had a moment of insanity and pushed the button on some GS1000i from amazon in a warehouse deal (UK)- half RRP but slight scratches to wood. Am I going to love them- 325i at present.
that sounds so logical, i can't believe i didn't think of this.
not on these ones...(OT: i really like your avatar. if only i could find one with RD + PS1000)
Mine are made for fully liberated drivers at the moment...let me know if you are keen on partially liberated though. A few tweaks in the design and "Presto"...
Haha thanks! maybe photoshop may work? xD
Alright, will do
What is a partially liberated driver? I f you have a pic, that would be great, thanks.
Sorry, am out and about, so no pics, but it is simply a driver left in the plastic sleeve that slips out of the standard Grado cup. A fully liberated is one that has been taken out of the standard outer cup and removed from the plastic sleeve.
Right. Some woodies are made by fitting a Grado driver into a whole wooden cup while others are made by fitting the still-in-sleeve driver into a slip on cup. The HF-1 and 325 (among others) are examples of a sleeve of one material fitting into the cup of another.
So you're saying that the Ps-1000, SR325is are "half liberated"?
Never thought of it that way, but yes, I suppose so...except the PS1000 has a wooden inner sleeve doesn't it?
