Grado Fan Club!
Apr 19, 2021 at 4:02 PM Post #46,921 of 49,895
Valens7
Does anybody knows which pads are on the hemps? Standard or deluxe? Thanks.
It may be possible that Grado is using a different stock of pads for the Hemp, which they have labeled “F-Cushion”. I’m not sure what, if any, difference there is between them and Deluxe Flat pads but the surface texture of the foam feels a bit softer on TTVJ’s than the Hemp pads. Unfortunately, I don’t have any Standard Flat pads on hand to compare.
In fact, those pads no longer appear to be available on TTVJ’s store...
Apr 19, 2021 at 4:11 PM Post #46,922 of 49,895
clundbe1
Oslo, Norway
Standard if yours do not have these pen marks. Deluxe have the pen prick.
Apr 19, 2021 at 4:46 PM Post #46,923 of 49,895
reivaj
Geez the used Hemps on in the for sale forums sure disappear about as fast a graphics card in the current market geez lol. The last 3 people I inquired with on buying their Hemp's told me that they were sold before I could even say hi.
Apr 19, 2021 at 5:00 PM Post #46,924 of 49,895
Pirastro
TTVJ says that the Hemp comes with standard flat. This was discussed a few pages ago. I put deluxe pads on my Hemps and can't say I noticed much difference - if anything, just a little smoother in the highs, I think.
Apr 19, 2021 at 5:02 PM Post #46,925 of 49,895
Pirastro
Just buy them new. They are limited edition, and they are a steal at 420.
Apr 19, 2021 at 5:26 PM Post #46,926 of 49,895
Valens7
One benefit of buying the Hemp new is that you can request that Grado remove the badge from the grille. I asked TTVJ if that was something he’d be able to take care of for me and, sure enough, mine arrived without the badge
Apr 19, 2021 at 6:16 PM Post #46,927 of 49,895
reivaj
Actually... that might be enough justification for me to just buy it new. Plus that is kinda nice a customized.
Apr 19, 2021 at 6:22 PM Post #46,928 of 49,895
Luckyleo
Sarasota, FL USA
I noticed zero difference between the deluxe and standard flat.
Apr 19, 2021 at 8:36 PM Post #46,930 of 49,895
oryan_dunn
About to do a shootout of the SR-80e with the stock and L pads vs the Hemp. Interested to see if it is mostly the 'flat' pads which send the Hemp across the line
I only have the SR-60i, but I've got the stock, L, and TTVJ deluxe pads. I like the L best for comfort, the TTVJ give a bit of a bass boost, but have smaller sound stage. Depending on what I'm listening to, I bounce between L and the flat pads. I really wish I had somewhere local I could demo the Hemp or the RS2e.
Apr 19, 2021 at 9:17 PM Post #46,931 of 49,895
qua2k
Oregon
Curious, did they give you the badges loose since you wanted them off or none at all?
Apr 19, 2021 at 10:00 PM Post #46,932 of 49,895
Reinhold
Oasis
Thanks for your help :thumbsup:
Short time after my post, i‘ve got mails from Grado and Todd.
Gradoservice: we will have stock sometime in May
Todd: We are currently out of stock on the Flat pads but has a few pair of the deluxe version left. The Deluxe Flat Pads are treated and sound mor open than the stock flat pads. Once these are out of stock, we won’t have any more until June or later.
btw. Dekoni is also working on some aftermarket pads for Grado.
Dekoni: We are working on pads for the Grado but do not have a release date planned.
Sbaf has done some measurements.
Apr 20, 2021 at 7:25 AM Post #46,935 of 49,895
Heyyoudvd
