But seriously..If this is entry level...Wizardry!
Sit back , close your wallet and enjoy your 60e for a long time , there is no rush to try higher end versions.
i had a super nice cord. not replacing it. cat just ate it! anyone recommend a nice cord installer for say less than $700 balanced? i also prefer someone that does not have more than 90 days lead way. thanks
checked it out. thanks. which cable would you get for ps1k non e? just because gold is the most does not mean it wlil sound the best?
see i always say this. i was an engineer. physics tells me any cable that completes a circuit is the same. reality tells me cables sound vastly different. i cannot explain it. i cannot measure it. i can most certainly hear it. so much so i have honestly won dbt's. when i was younger i mean. i had golden ears. now i am an old man whos health is filing so i make no sonic claims about anything. except perhaps casually.
given that, i am thinking i will like copper better on them.
upstairs right now i am running dave with odin 2 cables. for loudspeakers though.
So after a few years of use, my e series cables have frayed and broke twice. The upper part after the Y split is totally stiff. Completely junk wires Grado uses... will rewire very soon. Maybe vent mod them since I'll have them opened.
my cable was enjoyed by my cat. i am going to put cardas bulk wire. since it is not high end cable does it matter if i splice it outside the cup? is 2" of grado wire going to matter? getting the cups apart is difficult. i can splice it outside the cups with a small bit of shrink tubing. then continue the cable. or do i really need to open it? in that case i will use better than cardas.
The E series already has some holes in the back of the driver, so up to you if you want more bass (I found them fine as they are)
The bass in my RS1i is really good. I´m enjoing it righ now. MmmExcellent point. I never really found the bass to lacking, tbh. But the highs are a bit harsh. So I was thinking of putting in some insulation on the grill and maybe dampen the back of the driver with dynamat or something like that. It's been over a year since I looked at mods for Grados, so I need to refresh my knowledge a bit.
I'd rather open them up and correctly replace the cables. I repaired the original wires by soldering them (duh), but they just frayed/ shorted in a different spot. As for the type of cables, no sense in getting expensive ones for a $90 pair of headphones. My HD600s sounded just find with the OEM cables. I'll just get decent quality copper. What's a good gauge?
