GR07 MK2 cable starting to fail
Aug 11, 2015 at 1:10 AM Post #2 of 9
IMO you should just buy new ones. Recabling is likely going to cost you more than $100 including round shipping and new cable.
Aug 11, 2015 at 9:33 AM Post #4 of 9
  Yeah, but how long until they break again? I want a permanent fix.
Hi,
This member once had their GR07 recabled.
http://www.head-fi.org/u/281322/doublea71
I can't remember where though a quick PM to the member should get some answers.
Aug 11, 2015 at 12:36 PM Post #6 of 9
I'm interested if there is any 'permanent fix' for this as well. I really can't find myself buying another GR07 after mine broke just after a year even with light home use. I'm wondering if anyone tried if it was feasible to incorporate hardwired replaceable connectors on the body without changing the sound signature?
Aug 11, 2015 at 1:46 PM Post #7 of 9
after owning them for few days i decided to return them at amazon.. i hear crackling sound and got paranoid about this issue. this is the problem with not detachable cable..
they sound amazing though..
Aug 13, 2015 at 9:51 PM Post #8 of 9
Just got a reply from BTG.
I can work on the GR-07's no problem. I could actually modify them to accept removable cables as well: http://btg-audio.com/webstore.htm#ecwid:category=2609209&mode=product&product=11546437
Let me know what type of cable you'd like installed on the headphones or if you want the mod done. Do note you'll need a cable after the mod is completed. I sell cables for around $100, but any westone 2-pin styled cable will work!
So I'll be sending mine in soon.
