Good amp for the SR225's
Feb 19, 2009 at 9:07 PM Thread Starter Post #1 of 9
cakeman
I will be ordering these soon. I have SR60's at the moment.
Whats a good amp for these babies?
Keep it under 100USD
Feb 19, 2009 at 9:29 PM Post #2 of 9
Honestly, with Grado Prestige Series I would not bother with a $100 or less amp. They do pretty well straight out of a hp jack.
Now if you are a very hands-on person with soldering skills, a Millet Starving Student DIY would be a good way to go.
If it were me, I'd sock the Benjamin away, save up another one and get a better amp than $100 will net. At $200 there are much more and better options available.
Feb 19, 2009 at 9:53 PM Post #3 of 9
Ignore what he just said.
The Little Dot I+ amp has great synergy with the Grado series, and with the option to "tube roll," you can shape the resulting sound to your preference.
Feb 19, 2009 at 9:56 PM Post #4 of 9
I was looking for a portable amp though.
Meh How would the t4 work?
Feb 19, 2009 at 10:14 PM Post #7 of 9
i would also recommend the headroom total airhead. it's small,mobile and sound great with all cans i tried it with. it cost aproximately 99 $.
you can search it here in the forums or go to the headroom site.
good luck mate!
Feb 19, 2009 at 10:22 PM Post #8 of 9
Why not go for the Fii0 E5? Cheap. Rechargeable. Loudness function if you think you need it. Cute. And disposable (can't change out the battery, but it is cheap). I like mine. I use it with my Grado 325i (sometimes), but mostly with my Yuin PK1's.
Cheers.
Feb 19, 2009 at 10:25 PM Post #9 of 9
Do you find that the E5 softens the higher frequencies of your 325i? Thanks
