Going fully Wireless IEMs. Too soon? Or are we there yet?
609 610 611 612 613 614 615 616 617 618
620 621 622 623 624 625 626 627 628 629
  1. slipstreamrider
    I use iPhone and have no need for aptx. The faux leather case is nice but having something more pocketable is even better. I do like the low profile of the Anbes...I'd go for it if it was quicker to get a hold of.
    Originally my budget was going to be over $100, but after looking around I realized how quickly this tech is improving with all these options coming out left and right. Didn't want to splurge on something that will soon be dethroned by something $50 cheaper the next month.
    vstolpner likes this.
  2. Bartig
    The QCY T3 can take standard ear tips, but again with QCY, you won't be able to put them in the charging case anymore.
  3. speakerz2017
    I have always been a firm nonbeliever of wires affecting sonic quality significantly but once I got a decent bluetooth cable from Lear Audio. I did a 180 and am sticking to wired from now on. I mean the Lear bluetooth cable was not cheap but still I expected slightly more than muddled sound
  4. chinmie
    i use generic wide bores on my T1C that are shallow enough to still be able to charge in the case without problem, and it opens up the treble significantly compared to the stock tips (which have narrower bore nozzle)
  5. vstolpner
    If you want good noise isolation then go for Anbes 359
  6. actorlife
    Now these are cool looking. Highlights in Blue. Guess how much?
    [​IMG]
    • Style: In-Ear
    • Communication: Wireless
    • Connectors: None
    • Wireless Type: Bluetooth
    • Vocalism Principle: Dynamic
    • Control Button: Yes
    • Volume Control: Yes
    • Active Noise-Cancellation: Yes
    • Function: For Internet Bar
    • Function: Monitor Headphone
    • Function: for Video Game
    • Function: Common Headphone
    • Function: For Mobile Phone
    • Function: For iPod
    • Function: HiFi Headphone
    • Function: Sport
    • Plug Type: Wireless
    • Sensitivity: 110±4dB
    • Frequency Response Range: 100-10000Hz
    • Line Length: None
    • Resistance: 32Ω
    • Waterproof: Yes
    • Model Number: Z6
    • Support Memory Card: No
    • Support APP: No
    • Is wireless: Yes
    • With Microphone: Yes
    • Codecs: Apt-X HD
    • Brand Name: QCR
    • Name: Z6 TWS Wireless Bluetooth 5.0 Earphones
    • Charging box battery specification: 3000 mAh
    • Bluetooth: V5.0+
    • Earbuds waterproof level: IPX7 (shower,Snorkeling,Rain, sweat)
    • earphone battery capacity: 60mAh
    • earphones play time: 7-9Hours
    • Earbus standby: 120H
    • Compatibility: for iOS Android Smart Phone Smart tablet
    • Key: Touch
  7. clerkpalmer
    You have a link?
    actorlife likes this.
  8. vstolpner
    MrBiN, hifi80sman and actorlife like this.
  9. vstolpner
    I thoguht I saw these for $40 or so?
    I posted similar ones before - wasn't clear whether the "double driver" was an actual function or just pretty looking circuit board.
    Anyone willing to get these?
    Caipirina and actorlife like this.
  10. actorlife
    Yep you are correct sir. First time I see these clear Wireless. I think KZ is the only pair I have that has a bit of see through. I think it's one driver. I think those driver are just for show or maybe not. Slater might chime in.
    [​IMG]
    https://www.aliexpress.com/item/330...id=195amp-LCWGoRkYe8ac9MOYls3xsA1563719866286
  11. actorlife
    I'm throwing those on my want list in the future. Thanks for the review. [​IMG]
    d3myz and vstolpner like this.
  12. hifi80sman
    Pretty sure, if that's they way they actually look, it's just design, not function (pointed the wrong way, seems to be mounted on something gold, at the rear of the buds).
    The frequency response doesn't look too good and my guess, because I've seen it tons of times before with Chi-Fi, is that they mean aptX, which is "HD", and not actually "aptX HD".
    d3myz and actorlife like this.
  13. tsoltan
    Do you have a link for real anbes 359 on aliexpress?
  14. actorlife
    Bartig, Is this the box you got with the Anbes? If it is they are $22 on amazon:
    [​IMG]
    [​IMG]
  15. vstolpner
    Thanks!
    I'm thinking to check out something else from Tiso... Maybe i5 or ix....
    Anyone else interested in those?
    MrBiN likes this.
