Going fully Wireless IEMs. Too soon? Or are we there yet?
590 591 592 593 594 595 596 597 598 599
601 602 603 604 605 606 607 608 609 610
  1. Shanling
    Yes, they have it.
    Unfortunately not in this model. :frowning2:
    Shanling Have any question about our players? Just PM me or send me email. Stay updated on Shanling at their sponsor page on Head-Fi.
    Dcell7 likes this.
  2. vstolpner
    Will the ambient mode work while music is playing or only when paused?
  3. vstolpner
  4. Shanling
    Once enabled(hold finger on touch sensor for few seconds), it will be enabled until turned off. No matter if you are playing music or not.
    vstolpner likes this.
  5. Caipirina
    It’s the BA (pro) version
  6. clerkpalmer
  7. Heisenberg1895
    Been hunting high and low and can't fine any Aneb 359 anywhere (I'm in the UK) ive been trawling google all day.
    Would rather but then in the UK if possible but don't mind importing if there's no other option.
    Currently have TRANYA T3. So if u think I'd be better off just sticking with those please also say.
    Thanks
  8. Judge Buff
    If you’re referring to pressure within my ear, there is a gradual accumulation, but it’s no different than several IEMs I’ve owned. I typically just pull up on the top of my ear to release pressure and reseat the phone.
    The only negative here is that the tips are too large for the charging case to close correctly. This is also true for spin-fit and similar tips.
  9. FunctionalDoc
    I received the 1MORE Stylish True Wireless Earbuds today from Amazon.
    Impressions:
    Nice packaging
    Quality feel in the build
    Easy pairing to both my Hiby R6 Pro and Fiio M6
    Charging case nice feel and size and string magnets for holding the earbuds in place.
    Major Fail on Bluetooth range on these devices inside less then 10 feet and yes my house doesn't have steel studs or made out of concrete block.and I streamed Tidal on WiFi and then USB Audio Pro with the WiFi off and no change in receive range.
    The biggest issue is the low playing volume vert low level compared to my Nural NT01AX-BM HDSS True Wireless.
    I tried them because of the Prime day discount.
    I suggest that when people give recommendations on on connectivity tell what phones or DAP's they used and was inside or outside and there dwelling construction. I don't expect 60 ft inside just at least 15-20 ft without signal loss or stuttering.
    I noticed on my Nural NT01AX-BM HDSS True Wireless that cost a lot at $160 the range is poor on my Pixel XL version 1 and my R6 Pro vs the Fiio M6 which is rock solid and go anywhere in the house without a stutter or a drop. I was using Apt X on all devices in testing.
    Love the sound of Nural NT01AX-BM HDSS True Wireless since is not overemphasizing any frequency range put can hit the low end when needed. https://www.amazon.com/gp/product/B07QK89X59/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    I haven't decided yest if the Nural's are going back and try MPOW T5's or the new Sony's.
    I am looking for great sound , connectivity and build quality. Call quality is bonus.
    Thanks for letting me share.
  10. srinivasvignesh
    I did not get in on the prime deal for mpow t5 (was too late)... If anyone wants to part with theirs, please ping me directly via PM
  11. clerkpalmer
    Can’t find the t5 model on amazon. Anyone have a link?
  12. FunctionalDoc
  13. vstolpner
    The 359 and the T3 are somewhat similar but do have their own sound signature. They both have good base (with 359 being a touch less bassy but a fair bit more balanced). They both have good soundstage (359 a touch wider I think.... Still playing with it). The 359's are smaller but T3'S buttons are easier to press. The 359's case is more pocketable.
    Up to you if you want both. But if you're looking for more balanced signature, maybe ask someone between the 359 and the MPOW T5. In fact that comparison may have already been explained here
  14. joshnor713
    Anyone else with the Senn MTW do the new firmware 1.26 update? Am I crazy or is there a significant taming to the bass? I noticed right away after the update that the SQ is better. Bass doesn't sound as bloaty (which has long been my biggest pet-peeve of this earphone), and treble is clearer (this could be a result of the toned-down bass). Pretty sure I'm not crazy. These sound fantastic to me now, where they sounded just above-average before.
    hifi80sman likes this.
  15. oranelle
