Going fully Wireless IEMs. Too soon? Or are we there yet?
328 329 330 331 332 333 334 335 336 337
339 340 341 342 343 344 345 346 347 348
  1. SomeGuyDude
    How does a pair of $300 flagships compare to a set of $23 chi-fi? Hmm...
  2. smaragd
    The same as comparing a VW Golf with a Porsche...
    Both do the job but with a different user experience.
  3. Inear
    1 day left until Adv-sound announces their new TWS.
    https://www.adv-sound.com/
    I hope it's reasonably priced and 5 hours of battery.
  4. MulberryMadness
    ...true, but...https://jalopnik.com/why-volkswagens-are-the-only-cars-that-can-drive-faster-1540470407 only VW's can drive faster than 280mph, which no Porsche(unmodified/aftermkt tuned) can do no matter how much wealth you have, lol. And too call $300 a 'flagship' only goes to show how feeble/limited these early gen TWEs are. Give it a couple of yrs, we'll see >$1k TWE no doubt. HiFiman & Senn will have 'flagship' TWEs for your $2k+ iphone XS Max+++ in 2025 for only $3k-10k+, I predict!
    Comparing $30 chi-fi TWE is fair when $300 TWE 'flagship' are still giving SQ = <$100 wired iems.
    monsieurfromag3 likes this.
  5. MulberryMadness
    Given model 3 is $100, guess X will be ~$200...now what about the specs, codec support-what chip did they use...custom MSU, etc?
  6. MulberryMadness
    Don't think that is a good description of how BT 5.0 works.
  7. 05stisilver
    I confirmed with Advance no aptx support but they do support aac
  8. MulberryMadness
    So I'm wondering, hate how many versions we can't keep strait on these Chi-Fi brands...did you try the KZ7s yet? Seems reddit user thinks they work well with the TRN adapter
    https://www.reddit.com/r/headphones/comments/aj0lot/combo_review_trn_bt20_and_kz_zs7/
    , which has plenty of hiss when used with sensitive iem, CA, some Shure, etc https://www.headphone.com/blogs/news/campfire-audio-orion-in-ear-monitors-review
    "paired with the TRN BT20 wireless Bluetooth adapters, the Orions had very noticeable hiss or white noise. This was also the case with the Monolith THX-AAA Balanced DAC/Amp. With the use of the iFi IEMatch2.5, the problem went away. In short, I recommend having a very low output impedance and quiet source to pair with the Orions. The IEMatch is also handy regardless as it’ll make the Orions work universally."
    incorrect notation that bt20 does only SBC in one review, it has AAC support also, enough to get good review from someone using CIEM planar :https://forum.headphone.com/t/wireless-headphones-yay-or-nay/664/110
    Different case, but same BT 5.0 earphones? http://www.thephonograph.net/qcy-t1-pro-touch-control-review/ I might try those, bc they have decent sound isolation.
    Was also considering:https://www.amazon.com/dp/B07MHN4Z61/ref=sspa_dk_hqp_detail_aax_0?psc=1
    Thank is was this linked article that got me searching for the Tranya T2:https://www.headphonesty.com/2018/06/why-you-should-buy-true-wireless-headphones/
    Anyone try those? https://www.amazon.com/Bluetooth-Wi...es/dp/B07KW1ZPVM?ref_=bl_dp_s_web_15077608011
    I'm sure I'll drop these into the sink/bathtub, so need to buy 2 pairs at a time, or get some with superior water resistance rating. Though if I just go for the clunky/bulky TRN adapter/KZ 7 setup, I can spend <$100, and wait another 6-12mo for something better in tiny TWEs with longer runtimes, better SQ etc, that more than likely will appear :)
  9. hifi80sman
    As an answer to his specific question, I completely disagree. I'm not defining BT 5, I'm addressing his specific question with a simple answer. Based on your responses, I understand you like details, details, details, but sometimes simplicity is genius.
  10. Morbeas
    I just went ahead and bought the Jabra Elite Active in navy and so far I'm very pleased with both call and music quality. The one complaint I have are the included ear tips. Any recommendations for replacing the stock tips with more comfortable options? I'd like to be able to wear them for long stretches of time, if possible.
  11. clerkpalmer
    Anyone think the new Galaxy Buds will offer significant improvements on the current gen?
  12. Inear
    Does aptx be a bigger difference than just supporting aac? Also, you have any idea of battery life, usb-c, price? I assume since it will be on indiegogo, it will be cheaper for early buyers.
  13. hifi80sman
    In terms of audio quality, I'm not optimistic. Samsung has a history of making great flagship products, but the accessories are merely "consumer-grade", although I suppose that fits into the business strategy and overall profitability. It may have the proprietary "Samsung HD" codec (whatever that is, might just be some DSP magic) and will sound "good", but I don't think it'll be anything like the MW07, MTW, or even the E8. The target buyer is likely someone NOT on these forums.
  14. hifi80sman
    Depends.
    Apple Music over iPhone (AAC), sounds great. If you're a Spotify (320 kbps) user, Spotify (320 kbps) over Android aptX or LDAC sounds better than Spotify (320 kbps) over iPhone AAC.
    Spotify (320 kbps) over Android aptX or LDAC, sounds better than Spotify (320 kbps) over Android AAC.
    I have both an iPhone Xs Max (AAC) and a Samsung Galaxy s8 (aptX & LDAC). Using some HPs with multi-connect, I can easily A/B and toggle between them. Also, if you've enabled Developer Options on your Android device, you can easily toggle between the codecs.
  15. chinmie
    i dunked the Mifo o5 in a glass of water, used it in showers and bathtubs, it survives just fine. now that is a product that brings me a peace of mind :ksc75smile:
    between Aptx and AAC, i think the difference is really minimal unless i over-analyze. to my experience the AAC has a slightly smoother treble and fuller bass feel, while Aptx is slightly cleaner/leaner in bass and a bit more sparkle in treble. but again, the difference is really small that most of the time i don't care.
    SBC though, it's more squashed/flatter in soundstage depth and a bit harsher in treble. although hearing garage rock or indie music on SBC are rather exciting
    all in all, i nowadays i just view them like changing cables: each has their uses
