MulberryMadness
- Jul 30, 2011
@Bartig , I clicked on the Amazon link your blog links to, out-of-stock on that particular...but rt below, another suggested qcy model @29.99, then I clicked on the 'qcy factory' to see all the qcy models currently carried by AMZ, u say the t1c is not as good, but what about those in the qcy factory list? T1 Pro, clicked on that, got me to 3 versions under that link, t2 is the top/expensive @49.99. Anyone tried those, compared to others?Yes, just another design that sells to everyone who wants to put their brand on it. Ordered the Sabbat X12 for 38 euros/ 43 dollar. Can't wait.
Hmm, before spending that much on tws, have you tried the QCY QS1? They're 25 dollar and amazing! Full bodied and balanced sound, well extended and fairly detailed. Very pleasant sound signature.
https://www.amazon.com/Upgraded-Wireless-Headphones-Lightweight-Bluetooth/dp/B07JZ455HD/ref=sr_1_4?ie=UTF8&qid=1550172675&sr=8-4&keywords=QCY+Factory&th=1
Can't get a direct link to the T2 model-which seems the latest model with longest runtime, click on the link to T1 Pro from above, then you'll see the 3 options, it's the Linpa which can be ordered from Amz & fullfilled via Amz/Linpa and get it tomorrow!
Linpa World T2
Ya, so many rebrands of cheap Chi-Fi gear, almost imposslble to navigate, reason when my Bose qc30's bit the dust for the 3rd time, I simply had to order a quick replacement that I knew wasn't going to be the unreliably cheap Chi-Fi, and went with the 'spendy' old-style neck band, and proven qualcomm chip. Fiios F1 for $40. then again, one comment to headphonia's lack luster review, claims these 'suck' https://www.headfonia.com/review-fiio-fb1/ , though there is no actual review of how these sound (reviewer couldn't get a good fit with bulky size)
BTW, 1st qc30 was replaced under warranty when the flimsy usb charging port on the neckband 'pushed' inwards to the point I couldn't get it to charge anymore after 6mo. 2nd pair replaced past warranty by Bose gratis, when started getting electrical connection 'shorts' inside the neckband such that the power light would blink wrong colors before refusing to charge.
Similar happened on the 3rd set, the remote is moisture sealed but inside the quality must be poor, as I was getting a 'beeping' warning sound coming through the earpieces, which was for 'stuck' on max setting volume shorting through either up or down toggle, had to quickly press one of those buttons to get rid of the loud annoying warning beeping, then it worked until it finally died and got a red light(error msg) when I plugged in the usb charging cable, super short temp yellow light, before quickly going to red. Enough of Bose qc30 poor quality components...done with that company. If they come out with a $300 TWE with ANC, I'm going to pass, way too spendy for such poor quality..reading Senn MTW gives me same anxiety over poor quality components/construction/software/firmware
