Fleeple
Ah heck yeah. Thank you!Thanks. They don’t work for me. I hate that completely plugged sensation.
Yep.
Yep.
I just want you to get the EX againInteresting. I wonder if they can make them sound better and fit better than the original falcon. Let us know. I have 400 plus tax ready to deploy.
I see that after looking at Noble's site. Their wording has not been updated on the page yet I guess. We can blame @FullCircle![]()
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
If they were on prime or at Best Buy it would be done. Remain irritated at customer service but who am I punishing them or me?I just want you to get the EX again![]()
Only if it was that easy...! It's already a tetris figuring out battery, driver and PCBA inside for custom-fit. New universal TWS needs a lot of planning... We haven't got anything ready to share at this point.There are some hurdles but battery contacts and mics should be out towards the edge for the mics to pick up better and shouldn't really change with the custom portion unless you are trying for a flush fit. I don't see flush fit being the choice though for those reasons and for ease of insertion and removal.
You guys putting out a better universal TWS anytime soon??
So, then you are gonna get those iReep stage enhancing tips for the EX and go to the next level right??![]()
Getting back a little on-topic, the huge case shows you just why I bought Bose QC TWS… it also, like the over ears Sony XM3 and Bose 700 have a big flaw: you can’t just put them on your head and immediately listen like a TWS. The Sony XMs are a particular annoyance with the finger catching hinge, rotation, moving the creaky headband to the right position, switching them on and waiting for them to connect.Apologies for side tracking.
I got this case (arriving today) and I can’t get it around my head why it is so cheap (~4$). Even on AliExpress, same model costs 13+$
That’s a strange one. I had the CA MT before and had multiple issues but BT asking for pin wasn’t one of them and first time seeing it, but yeah they do have two separate BT connections.Just got the melomania audio touch....already returning 🙂 Bluetooth is two separate connections, and just kept getting the pop-up that says 'Incorrect Pin'...which Google says would require me to delete all Bluetooth devices connected to my phone and reset my bluetooth. So.....yeah. Just a heads-up to any potential buyers out there.
Admittedly it happened after I saw there was two connections and had my phone forget them because I thought it was a bug, but that's never caused another pair to have this issue.....That’s a strange one. I had the CA MT before and had multiple issues but BT asking for pin wasn’t one of them and first time seeing it, but yeah they do have two separate BT connections.
Sorry to be late on this… This is no longer as true as it was as there are now many different proprietary ways to send audio to the two sides that don’t involve primary/secondary SBC audio transmission between the two over NFMI. For example my 1More Evos don’t do this on LDAC.Btw, fun fact that most people who obsess about codecs don't know that their aptX, aptx HD or LDAC transmission actually happens to one earpiece only. Because unless you have a phone / TWS combo which supports synchronous streaming to both earpieces (Qualcomm's proprietary TWS+ technology, still used by just a small minority of configurations) , only the streaming from your phone to the master earpiece will use aptX, aptx HD or LDAC compression. The secondary transmission, however, from your master earpiece to the slave earpiece, will always use ... guess what? ... high bitrate SBC.![]()
I have had mine since almost launch, and have never seen that error; for myself, nor others complaining about.Admittedly it happened after I saw there was two connections and had my phone forget them because I thought it was a bug, but that's never caused another pair to have this issue.....
I would think a MMCX BT cable would not fall off since they click in quite securely.Hi everyone. Bit of a dilemma here. I'm looking for a set of bluetooth headphones that have a wire connecting them so that I can just drape them around my neck when not using them. I do have a pair of TWS (Jabra 75t), but I often don't bring the case since although it's on the smaller end of TWS cases, it's still quite bulky in the trouser pocket department. So often, when I need to take them out, I don't have anywhere to put them.
I thought about getting something like the Soundpeats Q35 or Beats Flex but then I realised I could get any wired IEM and get a bluetooth cable like the KZ bluetooth 5.0. The only issue I can see with this is that I will be hesitant to let the IEMs dangle around my neck knowing then might disconnect and fall. I was wondering if there are any solutions to this or perhaps something like the Soundpeats or Beats would be the best way to go. Or any other alternatives apart from the aforementioned two that also can click together magnetically and are permanently attached to the wire too.
Thanks.
Thanks.
https://www.us.jvc.com/headphones/wireless_earbuds/ha_a30t/
On the US JVC site now. They sound like they will be solid. Enough features and seems the selling points are the size and SQ. They can do a bunch with LL mode and ANC, ambient, call mute, and on board bass boost etc. Things like the ANC and calls seem to be fine but not gonna be up with the best just useful. Seems like really good connection, solid touch implementation and two worthwhile SQ reviews say they are much better than the first $99 JVC ANC and the other, while not very descriptive, did give these 5 stars in relation to the Liberty 3 pro. Should be a good budget option if the focus is fit, function, and SQ and you don't expect great ANC.
You could get the AT-Sport90BT since they are a good deal at current prices. They do magnetically attach. They do have 4GB of internal memory and play tunes themselves. They do have an amp that makes them sound quite nice. They are big and they are older so the battery life is nothing special. They also need better tips than they come with. They ambient is usable but has noticeable white noise but not many even have ambient so still a plus. Think you can still find them on Amazon for around $40. I got a used pair for $21 off Amazon and they have served me well. Not for everyone but worth a look.
