Tommy C
- Aug 22, 2011
Unfortunately I can’t answer that since I never had the T1 Lite.Thanks. Fill t1 lite should be the same size right?
That reminds me about the Creative Outlier Pro. Supposed to a hundred bucks or more but actually you can buy them from creative for $67.49 atm with a code. Not out yet though as it says April 20th they will be in stock. Not sure if this is a good thing or not.
Two vids I saw with a mic test that was not well done or the mic quality just isn't very good. Another vid was quick but stated they have a consumer sound with bigger bass and tamer treble than in the earlier versions of their TWS.
Yeah, I think that sounds reasonable, I'm still mad about it though... like sure, don't sell them in stores here.It looks like Samsung/AKG intentionally suppress the visibility of the N400 to make way for the Galaxy Buds Pro and siblings, which are selling like mad everywhere and becoming a must-have for non-headfiers.
Soundpeats H1, Moondrop Sparks, Sabbat E16I'm kinda looking at buying some new TWS's right now just to kinda... tide me over until my next "big" purchase, and while my Technics AZ60 are off for repair/replacement.
So I'm looking for something kinda cheap, sub $100-category kinda, available on Amazon( preferrably in an EU country), anyone have any suggestions?
Been looking so far at:
Earfun Free Pro 2 (for around €60)
Soundpeats Mini Pro (around $65)
LG FP8 (around $89)
1MORE Comfobuds Mini ($99)
1More Pistonbuds Pro ($59)
Lypertek Z3 ($99)
Galaxy Buds Pro ($109)
Soundcore Life P3/Liberty Air 2 Pro ($70-ish)
Or anything else that I might be missing in my list?
I sent the Gemini back for this reason. For me they just didn't have anything special to them. They were a nice enough sounding, however I had a few that were 3 times cheaper that could sound better....to me. When you spend $300 for tws you should expect top of the line across the board.It took me about 6 months and a switch to Android - but I don't dislike the Devialet Geminis anymore.
They are still not 100% able to perform and sound the way I would want them to, but to me the biggest issue with them is probably their limited in-app EQ?
There's nothing I can do in the app to make them sound good which was an issue when using iOS, but using Wavelet I can actually get them sounding pretty good.
What I still don't like is that even with EQ the mids just lack a bit of warmth and presence which affects vocals negatively, it sounds good but I know it could sound better.
The bass, while great for certain genres of electronic music, is also difficult to get any sort of natural sound to when it's more organic instrumentation, there's either a big "oomph" to it which kinda removes the character of the instrument, or if you EQ it down, the sound becomes the worst kind of flat and harsh to my ears.
I also feel like they're very sensitive to EQ in a way, changing the upper mids exposes the treble and makes them sound too sibilant and almost hurt my ears with just a small adjustment.
But with Wavelet they're definitely something like a 7/10 regarding sound, whereas before I thought they were a 5/10 and I could NOT understand why people were talking them up on here. I could see myself changing the EQ a little bit more and getting even better sound out of them too, so we'll see.
Hey what tips are you using?It took me about 6 months and a switch to Android - but I don't dislike the Devialet Geminis anymore.
How is the imaging and 3D aspect of the IEM? I like the idea of the EQ adjustments at lower volumes.
Possibly. Not sure. Maybe my CX 400BT weren’t running the most recent FW as I don’t use them that often like I used to.
Have the H1, not a huge fan but they're decent.Soundpeats H1, Moondrop Sparks, Sabbat E16
Sparks sound is wonderful, but no volume controls. Also, the fit is just plan weird. Not very ergonomic. I wound up returning them. But your ears may be differentHave the H1, not a huge fan but they're decent.
The Moondrop Sparks has a disgustingly long delivery time from Amazon (they say between June 11-June 16 as estimated date of delivery) and the Sabbat E16 aren't available here. /:
Honestly man... You are looking under $100. Another set that sounds fantastic is the Lypertek Soundfree S20 which normally sells for around $50 here. Looking at your list you've covered most sets. I can't remember if you had Tanchjim Echo on your list or not. Also, now that I think of it. Edifier Neobuds Pro have been discounted here routinely around $99. A great set if the fit is right and you'd likely need better tips. The tips they give are absolutely awful. Sound is fantastic, ANC is fantastic, ldac and a great transparency mode, great app.... Can't really beat it. Truthfully though if the H1 aren't that great to you than my question would be.... What sound signature are you after? Not many sub $100 are that much better than the H1 when SQ is concerned so I'm wondering if the signature just isn't sitting well with you? You can also find the Galaxy Buds Pro on sale for around $100 from time to time. The Nuarl N6 Pro are around $100 as well. I'll try to think of moreHave the H1, not a huge fan but they're decent.
Ya I felt the same as you about the volume controls... Hate that. Sound is nice though.Sparks sound is wonderful, but no volume controls. Also, the fit is just plan weird. Not very ergonomic. I wound up returning them. But your ears may be different![]()
