Going fully Wireless IEMs. Too soon? Or are we there yet?
Oct 16, 2021 at 1:37 PM Post #38,536 of 42,092
webvan
Went out for a run with the L3Ps and for the first time I wasn't too annoyed by the inevitable "thump" that comes with "IEMs"...but that requires the ANC to be on for some reason, without the thump is unbearable as usual. I also found that unlike with my fan test the "wind reduction" setting actually works when running. That's an unexpected bonus. The downside is that you can't hear your environment as you can with the X12s so it has to be in a non-dangerous area !
Has anyone had luck using multipoint with a Win10 computer ? I've found that when the W10 computer is connected the Android is not able to "reclaim" the connection even if the audio has been paused on the W10 device. Switching audio outputs, to say the speakers, will free the connection. Still it's rather inconvenient. That's a limitation of multipoint implementation by Soundcore as the Q30s have the same problem, unlike the Aftershockz or Jabra devices. Or am I missing something ?
Oct 16, 2021 at 2:42 PM Post #38,537 of 42,092
dweaver
OK I must be bored today. I looked down and realized I have 6 models of TWS sitting here. So took each headphone and set the volume to exact same spot on my phone (50%) and then played the exact same song Hans Zimmer Inception - We Built Our Own World. So lets see how they did. Starting with best to worst...
Before I get started on the ranking let me explain this song a bit. It starts with a sub-bassy heart beat and then has the orchestra play slowly come into play with an immersive encompassing sound they adds layers of complexity and intensity. When done right you get pulled into a 3D field of sound that is detailed and intense building to a crescendo over the minute fifty six seconds of the track.
Galaxy Buds Pro - the heartbeat has excellent feel and intensity, there is a wispy spacy back ground noise that is clear and easy with excellent presence. A guitar plucks a few lonely notes and then orchestra starts enveloping me in the music. Near the end of the track the main orchestra gives way to a strings section that slowly winds down the song with eery sounds appearing until the song ends. The bass never over whelms the song and the sense of immersion is complete from beginning to end with immense amounts of detail throughout the song.
Technics AZ70 - Sub-bass slightly less intense, spacy sounds are slightly less present but clear. Guitars is clear and articulate, orchestra comes in clearly with a bit wider feel. Strings at the end are slightly less intensity loading some of the eery feel.
Audiofly AFT2 - Heartbeat is slightly more nuanced and intense than even the GBuds Pro, spacy sounds are slightly warmer sounding, guitar kicks in with a warmer note that borders on being to rich. The orchestra kicks in and is also richer in tone. The strings similarly have a richer tone. The over experience is a bit to relaxed. For the song but very pleasant.
Status Between Pro - the heart beat is a bit to intense and not quite as nuanced as the first 3 buds. Spacy sounds are present but a lot further back due to the bass presence. The guitar has a nice tonality to it. When the orchestra kicks in it has almost a shouty edge to it. The strings sound right tonally but have a bit to much intensity. The overall sense throughout the whole song is that it's to in my face and intense.
Sony WF-1000XM3 - the heartbeat is a bit heavy and lack the detail of the other TWS above, spacy sounds are present but subdued and further back and lack detail. The guitar sounds nice in the mix and tonally correct. The orchestra is slightly to intense at moments and lacks a bit of detail. The strings at the end have good intesity. The over effect is decent but over whelming at points while simultaneously lacking detail and immersion.
Sennheiser CX400BT - Heartbeat lacks sub-bass intesity, spacy sounds are very distant and lack clarity and detail, guitar is present and tonally correct but slightly subdued. Orchestra lacks intensity and detail. The strings section at the end lacks vitality. The over all effect is one of listening almost from another room, losing the sense of immersion required for the song.
Oct 16, 2021 at 2:55 PM Post #38,538 of 42,092
voicemaster
So I've had anc both on and off. No I haven't tried the hear I'd on this set, I'm not holding my breath on these sounding any better. They don't sound bad, but, I would take the $40 Edifier Tws1 Pro over these in the SQ department. Everything else works great and they are stylish as hell. Look tough. Just thin... Mids both lower and upper... Thin. The highs are so splashy, tizzy, artificial sounding. Just like the L2P+... Just not a full and coherent implementation of a hybrid setup. I burned them in but only for about 4 hrs and to my ears nothing changed. Now, you can eq these to something approaching respectable but dude... I have many many sets of tws that imo blow these out of the water. Sucks. I purchased from Amazon so I have time to sit on these and hope by some miracle the sound changes. Maybe brain burn will kick in and I will report back that these sound amazing... Lol... This is all subjective though, but even saying that I don't know how many of you enjoy thin and tizzy. Crossing my fingers.... One other note, I will try hear id and maybe that will help out and I truly hope so however thin is something difficult to correct. I've done all my tricks, with tip changes, and manipulating the custom eq, trying the presets and I just feel like these are... At least for now... A step backwards for the tws world (strictly SQ speaking). I listen alot with my qudelix, or btr5, fiio dap, dongles and like you guys I want that wired full sound in a tws and I have been on a year long search in tws for that. The closest I have seen... IMO... Is the Lypertek Z7. For comparison sake... It's laughable to even compare LP3 to those as far as SQ goes. However every other feature, like the Sony Wf1000xm4 (returned) they have an awesome feature set which really makes it hard to put them back in the box and return them. Anyways sorry for writing a book.. Lol
Actually funny thing happened to me. I did the HearID thing and it make the sound super bright like piercing and tizzy treble. I even made fun of it here on my earlier post. Then someone mentioned here to try to listen using the HearID for several hours. I did that last night and funny thing was the piercing treble like 90% gone. I listen to it for 2-3 hours last night, trying several different songs that are prone to sibilance, but I couldn't hear any sibilance.
I could eliminate the piercing treble using the custom EQ, but I couldn't fattened up the mid using the EQ. If they have 32 bands EQ, it is possible to fine tuned it, but I haven't seen any 32 bands EQ on a smartphone ever.
With the HearID setting, the mid is fuller, treble is airy and not piercing than my custom EQ.
Oct 16, 2021 at 3:01 PM Post #38,539 of 42,092
voicemaster
Okay... I am slightly retracting my last post about 15 min ago... I just put them in and tried hear id. I should have started with hear id. It actually did correct a few issues. I also let them burn in last night, it seemed to help alot. What a crazy turn around. The thin note weight is actually much better and clarity is better. I just received a lesson in patience and using the tech they give you... Lol. I went from returning them to 20 min later thinking... Heh these are sounding pretty good.
That what happened to me too. This L3P change it sounds pretty drastically with burn in. From my experience, the bass tightened up pretty fast like 2-3 hours after first listening. The tizzy and piercing treble took around 20 hours to smoothened out. The mid is better using the HearID for me.
Oct 16, 2021 at 3:13 PM Post #38,540 of 42,092
jant71
N6 Pro 2 has one of the best tunings and everything sounds quite right and natural. Maybe with the wrong tips it is a little warmer and smooth than perfect but not the Senn and Sony and even JVC/Victor and AT route of smoothed over too much. I and other agree it is their best SQ yet like they touted. It just isn't the biggest stage they have gotten but still big but the Overall tuning and extension and detail and timbre is the best. They are not getting the fanfare they should though they get all good reviews(outside of one current one on Amazon but they clearly got a lemon). So many has tuning misfires in one area or another or just don't have the resolution.
Oct 16, 2021 at 3:38 PM Post #38,541 of 42,092
Tommy C
What you are describing re the CX 400BT is exactly how I felt for the first two days of listening here and there. I later found out the stock tips didn’t work for me despite getting a proper seal, or so I thought.
Try some tip rolling. I believe you’re not getting a proper seal with them yet.
Oct 16, 2021 at 7:01 PM Post #38,542 of 42,092
Ceeluh7
United States
So one thing that helped me to fine tune it... I obviously did everything within the Soundcore app itself to get the sound as close as possible to where it sounds good to me and then.. Since I use poweramp and can set Induvidual eq settings for any set, and you can set the amount of bands up to 32 I think... Pretty sure that's what I go with, can't remember but it's alot, anyways I fine tune it there and I found that the LP3 responds pretty well to eq. I have gotten something I hated in the morning to sounding pretty damn good. I do believe prolonged use will help the very subtle tizziness that still exists. Problem for me though is I also just got (today) the Grado Gt220....umm... Ya they are substantially better in almost every regard sound wise. Back to the Soundcore... I hope they update these considering their sound in the future
Oct 16, 2021 at 7:05 PM Post #38,543 of 42,092
dj24
U..S.A
Trying to switch things up from the LP3 Pro's, I recently ventured to Bart's site to checkout some of his latest reviews and saw these. As someone who spends 9+ hours on Cisco Jabber work calls every day- I'm very intrigued by them. Additional online and youtube reviews I checked out concur with Bart that these have the best noise cancellation for calls and now have the best call quality of any TWS sets out there.
The caveat is that they are currently only on Indiegogo and I remember people here mentioning that they've been burned ordering new products on that platform before. I've decided to take one for the team and just placed an order so I'll let you all know once I get them.
Oct 16, 2021 at 7:26 PM Post #38,544 of 42,092
Caipirina
Now, that suddenly makes them interesting for me. But then again. I really don’t need another pair. Perfectly happy alternating x12 / Bose QC and those cheapo Baseus W11 when it’s raining
Oct 16, 2021 at 8:06 PM Post #38,545 of 42,092
xSDMx
Exactly. The H1 are very well tuned and imo stack up sonically against most of the big boys and in some cases exceeds them. They have no bells and whistles... At all. Other than wireless charging and touch controls but what they lack in features they make up for in audio quality and for 75 bucks that's saying alot in this hobby. They look great, good passive noise isolation, and good audio throughout the entire spectrum. Of course I can find faults with anything sonically and the H1 have slight issues but... I love music and those things can play music really well
Out of curiosity, what tips are you rolling on your Soundpeats H1s?
The comply foam tips are too isolating for me (almost like active ANC!) And the stock silicone tips don't stay in and particularly well when active.
I've been using Spinfit CP360s which strike a good balance between isolation and fit. That said, they seem to notch the treble down slightly and boost the already booming bass. I suspect this is due to the bore size on the CP360 being slightly more narrow than the stock tips, so I'm looking for alternatives to try.
Oct 16, 2021 at 8:11 PM Post #38,546 of 42,092
CocaCola15
I'm going to do the same... I'm going to keep tweaking... I really like the build quality, & the other features. I have tried and tried to add more depth to the sound though and I am not losing the thinness. I have corrected the treble by bringing down the highs drastically and adding dbs to the mids. Still there is almost a lack of driving power in note weight... It's odd. The bass is pretty good, on the tighter side and can give a good rumble, slightly rounded and weighty response... But man, I love my mids and the more I tweak them it seems to make it more artificial. I don't want to push anyone away from buying these and everyone is different but I honestly cannot understand the tuning here... They've been doing the tws thing as long as anyone and this.... This is what their flagship sounds like.... Wth. Apparently they needed more Grammy awrd winning producers... Lol. Let's put it this way... I listened to these and then I thought, OK I'll a/b these with say.... Soundpeats h1. So I listen to these and get to a point where they are good and then I go to the H1 and I'm like.... These don't hold a damn candle to H1... Both hybrid. I check the Camb MT's... Not even close. I a/b with the Camb 1+....dude cambridge wipes the floor with them... Which I should expect so that's not too crazy. But I also go as low as the Z3's and truly the Z3's at least at this point are just much better tuned and even more capable... I tried them against my galaxy pro plus and galaxy is just more mature throughout the spectrum. Anyways I'm sorry for harping on these because it may just be my preferences and I don't want to just crap on them when many of you may really enjoy them, I don't want to do that..I also should state that they don't sound bad... Not saying that... You can get these to respectable and even to a point where you can look past certain things with the feature set and all that comes with them, I'm almost there and hopefully with hear Id and maybe try a few more tips and some burn-in & brain burn these will shape up... Just want a solution to a set I paid 160 bucks for and should exceed my expectations. Oh well... At least I bought them thru Amazon
I hear you! I am a major CA M1+ fanboy, sold my MTs. Also like my “cheap” Between Pros ($75 on Indiegogo) very much. But as much as I have managed to tame the fizzy highs, the L3P is not a better listen than either of those TW phones. I will give it a fair shake, but we’ll see. I like the idea that the M1+ is just great OOB, no futzing with ComplexEQ etc.
Oct 16, 2021 at 8:13 PM Post #38,547 of 42,092
Ceeluh7
United States
I've been using some tips from a pair of Fiio iems. I think the Fiio Fd3. I went thru many tips trying to find a pair that sealed really well in my ears and they helped alot with overall clarity as the stem inside is very firm and the bore is slightly wider, the bass tightened up as well.
Oct 16, 2021 at 8:19 PM Post #38,548 of 42,092
CocaCola15
Kaiser Audio app has 30-band EQ option.
Oct 16, 2021 at 8:19 PM Post #38,549 of 42,092
Ceeluh7
United States
I hear you! I am a major CA M1+ fanboy, sold my MTs. Also like my “cheap” Between Pros ($75 on Indiegogo) very much. But as much as I have managed to tame the fizzy highs, the L3P is not a better listen than either of those TW phones. I will give it a fair shake, but we’ll see. I like the idea that the M1+ is just great OOB, no futzing with Comlex EQ etc.
Totally man....you know what I'm talking about. Cambridge did an awesome job with their tuning and tonality. The M1+ should get way more praise. I recently changed up the tips on my 1+ (which is the hardest tips to roll because of the crazy wide tip), I used a slightly wider bore tip on these... I believe the 1more Quad driver tips, mediums so that they still fit in the case, anyways the seal was much better and just do a great job of opening these up. I now believe the 1+ is actually better than the Touch. I just can't part with these yet, you made a good choice
Oct 16, 2021 at 8:29 PM Post #38,550 of 42,092
Darkestred
What makes the 1+ better than the MT in your opinion? I liked the MTs a lot but their connectivity issues for me makes them bunk. Great before any firmware.
