clerkpalmer
- Dec 16, 2015
Anyone running these with Aptx adaptive or try to force aptxhd?B&O EQ hmmm .... better than PI7?
I thought so. Definitely from an overall flexibility and quality perspective. It's been a bit since I listened to the PI7s, but I would say they sound better to my ears than the PI7s did. Probably close though. I never used/had much use for the case audio relay of the PI7s, but it was a cool idea.B&O EQ hmmm .... better than PI7?
I think I agree that the overall tuning is really spot on. Using spin fits and they sound really awesome.I thought so. Definitely from an overall flexibility and quality perspective. It's been a bit since I listened to the PI7s, but I would say they sound better to my ears than the PI7s did. Probably close though. I never used/had much use for the case audio relay of the PI7s, but it was a cool idea.
I haven't tried any other outside of the Finals so far, but rock solid so far. Also like the simplicity of easily retuning something you need to adjust. I have become quite lazy listening to earbuds now and don't like to constantly jack around with a traditional EQ unless I am bored Battery life is also much better than PI7s. I will try and use aptxHD this weekend if I get time.I think I agree that the overall tuning is really spot on. Using spin fits and they sound really awesome.
Agreed. The approach to the EQ is genius. I have a pixel here with AptxHD - I'm not sure if they will connect or not. I'll check it out too.I haven't tried any other outside of the Finals so far, but rock solid so far. Also like the simplicity of easily retuning something you need to adjust. I have become quite lazy listening to earbuds now and don't like to constantly jack around with a traditional EQ unless I am bored Battery life is also much better than PI7s. I will try and use aptxHD this weekend if I get time.
I'm not sure if this was already mentioned, but do the Final Type E tips work well with your Gemini?These Sony XM4 with Final Type E TWS tips sound pretty damn good!
think I’m in the midst of a firmware update, too.
Yes they fit, and funny you should ask as I’m currently swapping back and forth between my final (L) and stock (M) to see which stay in better. Often wonder if I should have gotten medium finals.I'm not sure if this was already mentioned, but do the Final Type E tips work well with your Gemini?
I think the Sony sound really really good…better than I expected. But is it fair to say the Gemini feel more dynamic to me?I’ll try that out, thanks. Have it manually set now.
have to use another phone to update firmware…crashes with iOS 15 d’oh!
Most definitely. I liked the Sony too but the LDAC didn't make up for the fact that they still don't sound better than the Gemini, PI7, T5II ANC and now the EQ.But is it fair to say the Gemini feel more dynamic to me?
Where the Sony's shine out of that group I think are the features. Klipsch are the only ones comparable in that category. I absolutely love the touch hold ambient feature Sony uses, then the fade back in of audio (in case higher volume).Most definitely. I liked the Sony too but the LDAC didn't make up for the fact that they still don't sound better than the Gemini, PI7, T5II ANC and now the EQ.
Agreed and shouldn't be overlooked. If I needed one "do everything pair" for travel, work etc., the Sony would be the choice. That said, I don't since I never leave the house. So I'll take the improved SQ over the other features right now based on my priorities.Where the Sony's shine out of that group I think are the features. Klipsch are the only ones comparable in that category. I absolutely love the touch hold ambient feature Sony uses, then the fade back in of audio (in case higher volume).
Right on. I am keeping mine for my travel utilities and then keep the EQs for when SQ is desired.Agreed and shouldn't be overlooked. If I needed one "do everything pair" for travel, work etc., the Sony would be the choice. That said, I don't since I never leave the house. So I'll take the improved SQ over the other features right now based on my priorities.
Very similar thought pattern, but I expressed the conclusion in my head as “features shmeatures”Agreed and shouldn't be overlooked. If I needed one "do everything pair" for travel, work etc., the Sony would be the choice. That said, I don't since I never leave the house. So I'll take the improved SQ over the other features right now based on my priorities.
The ANC is really underrated. Right there with the bose and Sony. Maybe a notch below but waaaay better than the garbage "get me over" ANC offered by many others.Very similar thought pattern, but I expressed the conclusion in my head as “features shmeatures”
In addition to the SQ of Gemini that I love, I took them out into the City yesterday and the ANC was remarkable both just walking around and in the subway.
Well said. Seems as though we aren’t alone in ANC props for Gemini. Saw this yesterdayThe ANC is really underrated. Right there with the bose and Sony. Maybe a notch below but waaaay better than the garbage "get me over" ANC offered by many others.
