Going fully Wireless IEMs. Too soon? Or are we there yet?
Jun 9, 2021 at 1:24 AM Post #34,021 of 35,454
Caipirina
I am starting to get a bit worried about the fit of the XM4 … this German dude had them for a week, and this is the best fit he found?
Jun 9, 2021 at 1:45 AM Post #34,022 of 35,454
chinmie
Jakarta
Jun 9, 2021 at 2:16 AM Post #34,025 of 35,454
bladefd
USA
Not sure if I'm doing something wrong, but I can only get the right bud to work independently.
Their chip might be limited in that perspective then. Independent pairing should be the norm nowadays imo - that and multipoint
Jun 9, 2021 at 2:24 AM Post #34,026 of 35,454
webvan
Yeah that's bad, it's the sort of fit I got with the SiFi I, MPOW M5 or the Panasonics, unless you have small ears that form factor really doesn't work as there is nothing to hold the buds in place. Not sure what manufacturers are thinking as the Echo Buds 2 are similar. Make them larger but less deep !
Jun 9, 2021 at 4:10 AM Post #34,027 of 35,454
FYLegend
So I have the XM4's and I've listen them for about 20 minutes to make some first impressions:
First thing, YMMV, but they fit MUCH better than the XM3's. They are not the most comfortable TWS I've ever wore (Damn you MT. Damn you all to hell), but they are more secure and I can get a better seal with the foam tips more consistently. For my admittedly large ear holes, they sit flatter than the XM3, and I would say they actually are in my ear a tiny bit shallower than the XM3. However, they are still rather large, they're no Galaxy Buds Pro.
The case is a little more than half the height of the XM3 case, about 25% less long, and very slightly less wide. The case opening is pretty loose, but open it far enough, and it clicks and locks open. Much more portable.
So the bad news first: If you use the app to get the optimal "wearing condition" to get the best seal to have the most efficient ANC, these things are bass monsters. Also, the mids are weirdly tuned out of the box, and the treble roll off is considerable. They are very dark, very much the Sony house sound.
However, the EQ does work pretty well. It's not the most granular I've ever seen, but it does make a difference. This is the settings I'm currently using based on the measurements that SoundGuys posted on their review to try and even out some of the peaks and valleys.:
It tames the booming bass quite well, and makes it sound much less darker than before. I'm still tweaking things as I hear more. Again, your YMMV dependent on your listening preferences.
Overall, the tech and form factors are so much better than the XM3. Sound wise, due to the improved fit, I actually like them even if I have to tweak the EQ to tame the bass.
Edit: Also a tip for those that are getting it: Update your sony headphone app. The fast pairing didn't work for me at first, until I updated the app.
Edit 2: I ended up boosting the 6.3k and 16k to +2 and +3 respectively. But I think for me, it's the 6.3k is the one I'm going to be tweaking the most, it's the one that is sounding "off" for me dependent on what music I'm listening to. Haven't figure the best level for me yet.
Are EQ settings saved onto the earbuds so that I can use them across multiple platforms, or does it just work for the earbuds?
Any info about the SBC bitpool? You're still stuck with SBC on Windows 10 so it better be 52-53...
Jun 9, 2021 at 8:29 AM Post #34,031 of 35,454
Darkestred
One of the videos, I've heard it's 10% smaller? That 90% had to be shifted in other ways so that it doesn't point out like before, but it looks a bit bulky still. Also, that might be a small head though. lol
The more reviews I'm seeing, I'm less and less thrilled with the ergonomics. I get a feeling it will pop out while jobbing.
monster...indeed...recruiters...sweating...can't miss a beat when i upload my resume. haha. sorry.
Shame so far on the sony's. Still dont need another pair of TWS, yet i want one.
Jun 9, 2021 at 8:33 AM Post #34,032 of 35,454
SilverEars
Tame the bass? Don't like the sound of that. I hope they didn't tunr it like the full-sized bass. I wouldn't be surprised if they did as the audience is mainstream.
Jun 9, 2021 at 12:13 PM Post #34,034 of 35,454
C_Lindbergh
Sweden
